#1 Posted : Tuesday, 31 January 2006 7:44:49 AM(UTC)
what is a good diff ratio for a vs. It is curently standard ratio lsd, i want it to be quick off the line but i have to also use the car as a everyday car. i have to get my diff rebuilt soon because the lsd is only spining one wheel, so i think it just needs new clutch's put in it. so i thought it would be the perfect time to change my diff gears.
#2 Posted : Tuesday, 31 January 2006 8:18:10 AM(UTC)
Around town & with a bit of freeway you can't go past 3.7s
If you never see over 80km/h then the 3.9s would be better.
A lot of people aim to achieve nothing in life
#3 Posted : Tuesday, 31 January 2006 5:35:41 PM(UTC)
my V6 VS2 statesman has a 3.08 + LPG best of both worlds , I went from Elizabeth in SA to Wentworth Vic and back with some other driving around for a total of $70.00.
#4 Posted : Tuesday, 31 January 2006 8:09:10 PM(UTC)
I think that utes and V6 commodore S' got a 3.27:1 ratio rear end. If so the gears are easy to come by as a lot of Falcons had this gearing. It also means that the correct speedo drive gears should be available new from Holden to suit the 3.27:1 rear end.
#5 Posted : Tuesday, 31 January 2006 9:28:10 PM(UTC)
im thinking mabey 3.75 or 3.82 might be ok, just might chew a bit more fuel
#6 Posted : Tuesday, 31 January 2006 9:33:36 PM(UTC)
They were all 3.08:1 standard, but there were some HSV models with 3.23:1, 3.45:1, and a 3.7:1
Being a BW78 series diff, means there's a huge range of gears available from 2.72:1 all the way up to 4.11:1
Locally assembled pintaras had either the 3.9
#7 Posted : Wednesday, 1 February 2006 4:04:17 AM(UTC)
a lot of people run 3.55 diffs but i want to be one step ahead, so im thinking of going for 3.75 or 3.82, which should give me more pull off the line
#8 Posted : Wednesday, 1 February 2006 7:55:43 AM(UTC)
is your vs a auto or 5 speed manaul???
zac
Nothing beats cubic inches !!!
#9 Posted : Wednesday, 1 February 2006 7:59:21 AM(UTC)
the vs is a standard auto, but i hope to have a shift kit fitted soon
Guest (9)
This page was generated in 0.170 seconds.
