#1 Posted : Tuesday, 31 January 2006 10:44:58 PM(UTC)
any of you guys able to tell me how I can check if the motor in my HG is it's original one without having the logbooks? Eng No 308H30425, Body No 24867S. The car has been off the road and unreg since Jan 1980, still has a NSW rego sticker on with that same eng No. Also info on where it was built etc if at all possible. Thanks in advance.
#2 Posted : Wednesday, 1 February 2006 3:03:27 AM(UTC)
Pagewood, Sydney built. Pretty close to the original engine number. I can check for you but I need the VIN number (ie skinny plate).
#3 Posted : Thursday, 2 February 2006 10:34:11 PM(UTC)
Mate, thank you . The numbers are a follows:
skinny plate: 81469GH670912
Model: 81469GR
Body: 24925S
Trim: 1192-18M
Paint: 568-11401
Top: Blank
Odd that the body numbers are different on each plate. Any way you can look up what options this ca
#4 Posted : Friday, 3 February 2006 4:08:39 AM(UTC)
I'll find out for you about the motor. Numbers are fine as is. Pagewood BODY number and PSN (yours is H670912) didn't line up until late HQ, and even then not for vans and tonners as the BODY plate was from Elizabeth (Adelaide) and the VIN from Pagewood.
