#1 Posted : Friday, 3 February 2006 3:26:50 AM(UTC)
Can anyone tell me if you can run a series 2 inlet manifold on a V6 series 1 engine. Any info would be appreciated.
#2 Posted : Friday, 3 February 2006 10:04:06 AM(UTC)
IIRC, the answer is no. Almost nothing interchanges between the S1 and S2 VN V6's.
Cheers...Dave
#3 Posted : Friday, 3 February 2006 8:05:49 PM(UTC)
Well I hope that it can be done because I intend to do it.
What I have been told to replace is inlet manifold complete with fuel rails, injectors & throttle body (although I have not found a difference in the TB's). There will also be some wiring ch
Edited by user Friday, 3 February 2006 9:24:14 PM(UTC)  | Reason: Not specified
#4 Posted : Saturday, 4 February 2006 1:37:42 AM(UTC)
u can do that but u must use complete inlet setup as per what jim5.0 says
#5 Posted : Saturday, 4 February 2006 9:19:01 AM(UTC)
Hi Jim,
I assumed Geoff was just asking about replacing a manifold. If you change the whole system, I'm fairly sure they will swap, but not the manifold only.
Cheers...Dave
Taz2 Offline
#6 Posted : Saturday, 4 February 2006 4:09:57 PM(UTC)
Taz2
Interesting thing with the throttle bodies.
They all appear to be the same....at least across the VN/Vp series.
I'm currently running a throttle body from a VN 5ltr on my VP V6, and it appears to be exactly the same as the V6 one.
I did the swap to hel
In thrust we trust
#7 Posted : Saturday, 4 February 2006 5:56:32 PM(UTC)
They are the same fitment & work the same way - but the V8 one is a little bigger in throttle blade diameter. A popular V6 mod is to chuck on a VN-VS V8 throttle body.
The TPS switch on the side of the TB is the same for VN-VR V6, VN-VS V8, and also G
