Hi all, Im new to this forum and got a question that will help me finish my conversion from a 6 cyl to a 308.Im being told a thousand things regarding the rear disc brake conversion from drums. firstly ive been told i need to change the brake booster,master cylinder,brake pedal...is this all true?? And ive also been told that a 68-82 corvette master will bolt straight up and wont have to change anything else...is this also true?? Any help and reply's would be very greatful !! cheers
Joined: 3/03/2005(UTC) Posts: 287 ![Australia Australia]()
I beleive its the master cylinder, proportioning valve and hand break setup at the rear.
Hi Guys.
To get it working all you need to do is to remove the small rubber back-pressure valve from the rear brake outlet olive in the master cyl & fit the correct handbrake cables. The master cyl is the same except for this valve.
To make it corre |
