#1 Posted : Sunday, 5 February 2006 9:39:08 PM(UTC)
Hi all, Im new to this forum and got a question that will help me finish my conversion from a 6 cyl to a 308.Im being told a thousand things regarding the rear disc brake conversion from drums.
firstly ive been told i need to change the brake booster,master cylinder,brake pedal...is this all true?? And ive also been told that a 68-82 corvette master will bolt straight up and wont have to change anything else...is this also true?? Any help and reply's would be very greatful !! cheers
crowe Offline
#2 Posted : Sunday, 5 February 2006 10:51:11 PM(UTC)
crowe
I beleive its the master cylinder, proportioning valve and hand break setup at the rear.
#3 Posted : Monday, 6 February 2006 12:29:59 AM(UTC)
Hi Guys.
To get it working all you need to do is to remove the small rubber back-pressure valve from the rear brake outlet olive in the master cyl & fit the correct handbrake cables. The master cyl is the same except for this valve.
To make it corre
