#1 Posted : Wednesday, 8 February 2006 11:27:49 PM(UTC)
Does anyone know of a LPG specialist Hastings/Mornington/Dandenong area?
She is a HQ 1TON full gas set up 253. On start up she tries to turn over, most of the time after 5-10 mins she will eventually turn over. Occasionally when this happen I turn the key to full ignition the car is dead although the battery is not dead. If I leave it sit for a while she will begin to turn over again. There is a smell of gas on these occasions. She has problems in the heat and also misses more times than not when I accelerate. I have had her serviced and tuned twice in 7 months and am getting no where. Any help would be appreciated.
Cheers Cal
#2 Posted : Thursday, 9 February 2006 4:03:32 AM(UTC)
If it is miss firing replace the leads , Gas has no mercy for old leads use 9mm leads, are you using upper cyl lubricant or drip system.Recharge the battery or go for at least 450cc battery, If the car is over heating get your radiator core cleaned out an
CherryBomb Offline
#3 Posted : Thursday, 9 February 2006 4:55:47 AM(UTC)
CherryBomb
I'm no expert on this LPG but I do think that a Full gas set up will knock the daylights out of a General run of the mill Battery. As the GAS dose need to be Vaporized from the tank (liquid) before its induced into the manifold(Gas). If I recall there is
Edited by user Thursday, 9 February 2006 4:58:50 AM(UTC)  | Reason: Not specified
Never stop being inspired,
#4 Posted : Thursday, 9 February 2006 5:11:06 AM(UTC)
My car is on LPG to and it is temperemental when its realy hot or cold. Next time it's hot and you have problems try to pris the prime button that is located in the back of the actual mixer/ converter, if you cant press it in or hear no sound of gas it me
#5 Posted : Thursday, 9 February 2006 7:26:13 AM(UTC)
if you're turning the key to full and getting no electrics, check the connections on the solenoid/starter.
FastEHHolden Offline
#6 Posted : Saturday, 11 February 2006 9:08:40 PM(UTC)
FastEHHolden
it really does sound like a dud battery if the starter won't turn your engine...this could be accompanied by a dud alternator.
#7 Posted : Sunday, 12 February 2006 12:44:03 PM(UTC)
Cal
If your engine will not crank over it has nothing to do with the LPG. Get an auto electrician to check it out. He will do an amperage draw test and check the voltage drop across the entire starting circuit.
LPG should not be hard to start in
bluHJ Offline
#8 Posted : Sunday, 12 February 2006 6:54:08 PM(UTC)
bluHJ
Cal
I've had gas powered cars since 1989 and haven't had this problem except for a starter problem. Gas needs a good fat spark. I run a VH electronic distributor with gas leads and 1 colder NGK plugs at 1.4mm Runs and starts extremely well. Gas
#9 Posted : Tuesday, 14 February 2006 2:31:37 AM(UTC)
You will find that the most likely cause of your problem is the ignition switch at the base of your steering colomb or poor contacts in your electrical system (battery terminals), I have had the same problem in a HQ 202, hard to start, or just no power at
#10 Posted : Wednesday, 15 February 2006 6:02:14 PM(UTC)
Thanks for all those who responed with their advice. I ended up getting her towed and the problem was the ignition switch, coil and some dodgy wiring.
Cheers and beers
Cal
