#1 Posted : Thursday, 9 February 2006 10:05:45 AM(UTC)
I have just snapped something in the column of my 3 on the tree HK. And my 3 speed is dead. I was having problems selecting gears so I serviced the gearbox. There was about half a litre of oil in it (which was like water) and after changing the oil, the gears still get stuck.
So now i need some info about what I can do/ what will fit.
at the moment it has a 173 with a HK 3 speed
what will bolt straight up? because HK 3 speeds in good condition are getting hard to find. I'd prefer something that bolts up to the same bellhousing.
HT or HG 3 speed (i heard they were slightly different. all synchro???
HQ-HZ 3 speed?
4 speed?
Since the column is stuffed I was just going to convert to floor shift
any help would be great
Munromad2004 Offline
#2 Posted : Thursday, 9 February 2006 5:14:35 PM(UTC)
Munromad2004
If you're in Adelaide I can sell you a complete column from a HG Kingswood for $50 including linkages etc.
It's a 3 speed, currently bolted to a 186 so it should fit no problems.
email 'munromad2004 at yahoo dot com'
#3 Posted : Friday, 10 February 2006 5:01:00 AM(UTC)
Hi sot.
If it's an HK it's most likely a 3-speed crash box (no synchro on 1st). The 3 sp all syncro was an option for HK but not common. It is standard though on both HT & HG.
It's probably jusy as easy to get a complete 3nd hand, column & box out o
