#1 Posted : Friday, 10 February 2006 12:34:24 AM(UTC)
guy's
i put the front of my hq back together, but the bonnet sits up to high at the windscreen end. I have lowered the bonnet hinges to as low as they can, but it still sits up about 12mm to high.....any advice!!
Also I have got 15" weld wheels on it, trouble is when I turn full lock, the front tyre rubs on the bottom of the wheel arch at the front of the car. what can i do........cheers
Munromad2004 Offline
#2 Posted : Friday, 10 February 2006 2:15:06 AM(UTC)
Munromad2004
I've got the same problem Phil but I haven't rally bothered to take the time to have a look at it.
The things that gets me is that it was aligned perfectly before I took it off.
Strange how that works.
CherryBomb Offline
#3 Posted : Friday, 10 February 2006 6:11:53 AM(UTC)
CherryBomb
Cant help with your Bonnet. But I know your frustration. :))
As for your 15" weldies. Most of the time this Rubbing happens because the Offset? These wheels came from the states and are a Multi fit pattern.
The only Way I know of fixing the problem
Never stop being inspired,
trubluhq Offline
#4 Posted : Friday, 10 February 2006 7:11:39 AM(UTC)
trubluhq
My Prem has the same problem too. Seems to be common.
John
crowe Offline
#5 Posted : Friday, 10 February 2006 9:00:56 AM(UTC)
crowe
try lowering the rear part of the hing and lift the front part up as high as you can. I know that defies logic but its something to do with hing bending geometry. Lower your bonet slowly as it will be over done and the edges/corners may dig in to low!!!
crowe Offline
#6 Posted : Friday, 10 February 2006 9:03:08 AM(UTC)
crowe
i mean hinge
