ChrisHQUTE Offline
#1 Posted : Thursday, 1 February 2007 8:13:52 AM(UTC)
ChrisHQUTE
I want to get the standard tacho working in the ute and was hoping someone could tell me which wire in the loom hooks up to the tacho or do I run a separate wire like an after market one does.
Thankyou Chris
If a man say's something in the woods and there is no women around, is he still wrong?
#2 Posted : Friday, 2 February 2007 4:10:59 AM(UTC)
Brown is usually the tacho wire colour.
Depends on what model as some do not have the wire in the harness.
Warren
ChrisHQUTE Offline
#3 Posted : Friday, 2 February 2007 5:18:47 AM(UTC)
ChrisHQUTE
Thanks Warren, It's a HX I will have a look at the wiring again.
Would putting power to different wires make the tacho "twitch" when the right wire is found, or do they work of earth?
ozjason Offline
#4 Posted : Friday, 2 February 2007 9:28:30 PM(UTC)
ozjason
Chris,
Are you trying to test the *tacho* by putting power (or earth) to it? That more than likely won't work by the way, as the tacho signal expects and alternating signal from the coil.
Easy way to test a tacho, is to run a wire directly from the
#5 Posted : Sunday, 4 February 2007 6:50:46 PM(UTC)
On an HX you will have a blank brown wire in the engine harness connector, just behind the engine, go from here to the wire that goes to the distributor.
Waren
ChrisHQUTE Offline
#6 Posted : Sunday, 4 February 2007 7:38:32 PM(UTC)
ChrisHQUTE
Thanks for your help very appreciated. Tacho is working now. The person who owned the car before me must have been a part time auto sparky, there's wires running everywhere that go nowhere. Thanks again for the help.
