#1 Posted : Sunday, 12 February 2006 12:45:04 AM(UTC)
with my HZ 253 (red), can I fit VN heads to it, do I need to machine the block for the valve clearance or will the std VN heads sit straight on.
Reason being I want to do away with the carbie setup and run a custom efi & manifold.
Has anyone done this and were there any hitches?
trubluhq Offline
#2 Posted : Sunday, 12 February 2006 2:37:21 AM(UTC)
trubluhq
I always wanted to do this myself, but I like a V8 to sound like one. Especially under the bonnet.
I believe the heads and manifold will bolt str8 on, BUT, you may have to pull the donk apart for piston-valve clearance. So shaved pistons may be needed
#3 Posted : Sunday, 12 February 2006 3:43:46 AM(UTC)
I thought about that but what I want is that tough look, I don't like the look of that new efi. I want the 8x trumpets. I was going to do it using 4x quad webbers untill I got the price for the carbs, so efi is the go.
trubluhq Offline
#4 Posted : Sunday, 12 February 2006 7:20:09 AM(UTC)
trubluhq
Hey yeah way to GO. That was also on my plans too...Well done...would sound and go awesome.
John
#5 Posted : Sunday, 12 February 2006 10:22:28 AM(UTC)
The heads will fit on no probs, the valves arn't too much of a problem depending on how much lift you have on the cam. .500" is fine, could probabley use a bit more but remember that the valves will be shrouded badly because of the bore.
Too much lift t
#6 Posted : Sunday, 12 February 2006 11:13:14 AM(UTC)
Also, don't forget you'll have to change your cam for an EFI one (different valve order on the VN and later V8's) and also change your exhaust manifolds/extractors.
Cheers...Dave
#7 Posted : Monday, 13 February 2006 2:32:48 AM(UTC)
Ahhh...now theres a trap, I was going to replace the cam but never thought about the different valve order.
Dave you're a life saver!!! I suspect I can pick up a set of extractors for the VN pretty easy.
Thanks sooo much Dave.
Darren
#8 Posted : Monday, 13 February 2006 3:41:37 AM(UTC)
stick with a 308 caus 253 will have no torque. valves are too large but it is possible
CherryBomb Offline
#9 Posted : Monday, 13 February 2006 4:24:30 AM(UTC)
CherryBomb
And If Im not mistaken, All Cams available are rollers! There bloody dear little buggers too. $500 just for a cam, $700 for the Kits on some.
The VN Heads are pretty good flowing Heads. If I recall strait out of there Box they can flow up there of 500H
Never stop being inspired,
trubluhq Offline
#10 Posted : Monday, 13 February 2006 8:14:39 PM(UTC)
trubluhq
And just remember when it dies in the ass at some out of the way place, you know how to fix it right ? Just go over to Kmart and get some spare parts. Thats why basic motors work.
Just increase the mix on the 2 strommie/quad idle circuits...increase t
Dylan Offline
#11 Posted : Monday, 13 February 2006 11:41:28 PM(UTC)
Dylan
only VT/VSIII engines are roller cam. VN - VS are all flat tappet hydraulic cams like any other 253/308.
CherryBomb Offline
#12 Posted : Wednesday, 15 February 2006 5:29:55 AM(UTC)
CherryBomb
Is that true Dylan? I was thinking that the Rollers came out way before the VS? - Still Hydraulics.
Or was it the VN SV5000 twin TB's a Roller?
Dan
Edited by user Wednesday, 15 February 2006 6:19:46 AM(UTC)  | Reason: Not specified
