Fastlane
Holden Forums
Holden General Discussion
Lifters / push rods Head work on Red motor
Ok guys I am gonna buy a new cam for the project and have selected the Crow cams towing beastie as my weapon of choice, but now I know I will have to replace the lifters and may as well do the pushrods at the same time, I dont have a clue what to put in, I have been told use std ones, then pump up ones then Anti pump up ones, and quite franky I am confused! and I havnt even started on the Pushrods yet! hehe Also I am thinking of getting the head work done soon and would like to make sure everything will match so what should I be looking out for with that as well? Matt
Looking for Old Caravans!!!! especially 1950's ply ones! Thanks! |
1962 EK Wagon - Chev SBC & T700, 1962 EK Sedan - Chev SBC & T700,EK Ute - V6 Buick & 5 speed = LOOKING FOR A 1962 EK VAN |
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
Which size red 6 is it again? |
Hi Byron, It is a HQ 202 red motor, with all blue bottom end and keeping red head but not too sure what I will get done to head yet? maybe roller rockers and porting also get it set up for Unleaded with hardened valve seats? Matt
Looking for Old Cara |
Don't port it much. Just use a 179 or 186 head with inlet posts removed. I've got one here already done if you want to buy it. It will need a clean and service plus hardened seats. Email me privately. I'll look for it tomorrow. |
if your getting a new cam, you will also need to replace the standard timing gears with new ones, as the standard ones arnt really reliable.
Hi Matt, Yeah, make sure you put alloy timing gears in her. They are noisier than the fibre ones but MUCH more relaible in the long run. Also, I agree with Byron, don't go too big with your ports as you will lose bottom-end torque and, IIRC, you wan Edited by user Sunday, 12 February 2006 11:27:33 AM(UTC)
| Reason: Not specified
Thanks guys I should have mentioned I have nem JP performance Allow timing gears for her.... Matt
I would just go for what Crow recommends for Lifters - Hydraulics. Push rods are pretty simple. Just go for stock length replacement 202 NOT 186 Rods. Never stop being inspired, You may never realize your full potential. Edited by user Monday, 13 February 2006 4:45:22 AM(UTC)
| Reason: Not specified |
Never stop being inspired, You may never realize your full potential. |
Fastlane
Holden Forums
