Munromad2004 Offline
#1 Posted : Monday, 13 February 2006 9:08:34 PM(UTC)
Munromad2004
Hi all,
Does anyone have any comments on the following regarding price, quality etc
Exchange 308 red motor (turbo block) from HM engines. $2350
Complete from sump to rocker covers
Has ULP/Gas heads
12 months/100,000km warranty
I have spoken to the company and they stated that they only bore/hone to the minimum required (ie not always 60thou)
They use all new bearings and pistons.
Valve guides replaced as necessary, valves as required.
I would be interested to hear your input/experiences with this company.
If you know of another company that does it better/cheaper then I'm all ears too.
regards
Darren
Dylan Offline
#2 Posted : Monday, 13 February 2006 11:36:57 PM(UTC)
Dylan
i have heard nothing but bad things about engines from HM and companies like them (RPM etc.) pay the extra for a real engine builder to do it.
Edited by user Monday, 13 February 2006 11:38:08 PM(UTC)  | Reason: Not specified
#3 Posted : Tuesday, 14 February 2006 1:14:49 AM(UTC)
Munromad2004
Please elaborate???
I have heard a few rumours but when I phoned them they seemed very professional and willing to help.
They insist they don't automatically bore out engines unless they need it. There was a rumour that they always bored each engin
hairy-dude Offline
#4 Posted : Tuesday, 14 February 2006 1:43:54 AM(UTC)
hairy-dude
Be careful with the warranties - read the fine print. For your motor to be covered under warranty, you have to replace/recondition just about everything else around it - starter, alternator, dizzy, radiator etc. They also specify regular services, which i
#5 Posted : Tuesday, 14 February 2006 2:22:43 AM(UTC)
Munromad2004
Thanks Hairy, I tried a search before my initial post but got nothing although I do remember reading something a while back.
I'll try again.
I will look in to the warranty stuff too.
#6 Posted : Tuesday, 14 February 2006 8:17:26 AM(UTC)
I had to put a long eng into a mistake of a EA falcon, ended up getting a repco (GEM)eng, All i had probs with were the lifters as these were not replaced...don't know why but thats there policy for that eng??? their warranty is stritck (Very). I had the
HZ-GED Offline
#7 Posted : Tuesday, 14 February 2006 8:37:09 AM(UTC)
HZ-GED
Hi;
I had one of these change-over long 308 motors from Repco 5 years ago. A stock engine, and yes the warranties are a load of crap as they are very strcit. however, the engine itself hasn't missed a beat. I run it on straight gas, it still goes strong
#8 Posted : Friday, 17 February 2006 9:40:43 PM(UTC)
if you can, your best bet (this is what i did with my 308). Try and find someone that builds motors, not a large company. go and meet him. Tell him exactly what you want. Find out which shop he will be using for machining your heads, block etc. Have a loo
#9 Posted : Friday, 17 February 2006 11:20:52 PM(UTC)
Munromad2004
Here is the reply I received from my enquiry.
Hi there Darren,
Thank you for your enquiry.You may service your own vehicle,but i suggest u keep records of when u do this,
just in case a problem does occur.
Warranty details are 12mths unlimited kms
CherryBomb Offline
#10 Posted : Saturday, 18 February 2006 7:29:44 AM(UTC)
CherryBomb
Its interesting in that that they now allow there engines to be serviced by you! I have one in my HR (it come with the car upon sale 3 years prior) and as said There warranty was pretty strict with service. Basically You had to prove it was done by a Regi
Never stop being inspired,
#11 Posted : Saturday, 18 February 2006 9:17:21 AM(UTC)
Munromad2004
I'm pretty happy with all the info I have received from the company and as a result I will be purchasing an exchange engine for my GTS.
A stock engine is exactly what I require and I believe that for $2350 I couldn't do it myself (depending on machinin
#12 Posted : Saturday, 18 February 2006 1:14:15 PM(UTC)
I haven't really priced everything but I cannot believe you can't do an engine at home for a lot less than $2350. Assuming you have the confidence to assemble stuff yourself. Let's face it, engine assembly is done in Holdens factory (or any factory) by im
Edited by user Saturday, 18 February 2006 1:17:37 PM(UTC)  | Reason: Not specified
#13 Posted : Sunday, 19 February 2006 1:20:54 AM(UTC)
Munromad2004
You are correct John, it certainly could be done cheaper than that and I am able to do it myself but I think the running around and time saved is worth those few hundred bucks.
One thing you left out is a new oil pump which is not cheap either.
I th
#14 Posted : Sunday, 19 February 2006 1:33:29 AM(UTC)
Doesn't cost much to rebore the cam bearings. All the parts can be picked up on Ebay really cheap. Gaskets sets $35-$40, big ends and mains $30 -$40 , rings $35, oil pumps $30, camshafts new for $70,don't make the mistake of fitting a high pressure pump,
HZ-GED Offline
#15 Posted : Sunday, 19 February 2006 9:07:42 PM(UTC)
HZ-GED
With fitting a change-over engine in a genuine GTS - is this going to effect your matching numbers if the engine you have is the original one? It would pay to rebuild the one you have if you want it to match up still. Spend over 2000 on the one youv'e got
#16 Posted : Monday, 20 February 2006 4:03:06 AM(UTC)
Munromad2004
Unfortunately I don't have the original engine for the GTS. I haved an 11QT motor which I ripped from a HJ Staesman.
The GTS was originally a 253.M20 and I will be fittign a 308/Turbo 400 and powers steerign from the Statesman. Should make it a much ni
