#1 Posted : Wednesday, 22 February 2006 3:46:21 AM(UTC)
I've got a problem with my car - it refuses to rev over 1500 or so when the trimatic is in gear, and won't rev past 2000 or so when in neutral. The revs seem like they're being limited by something - does the distributer advance at thoser revs? I've got electronic ignition, and it does the same thinkg with both gas and petrol.
Any ideas would be very much appreciated.
peter_flane Offline
#2 Posted : Wednesday, 22 February 2006 8:02:53 AM(UTC)
peter_flane
Drive it very carefully to a mechanic.
#3 Posted : Wednesday, 22 February 2006 8:25:01 AM(UTC)
Thanks Pete, but no thanks. Anyone else?
#4 Posted : Wednesday, 22 February 2006 8:33:16 AM(UTC)
Put a timing light on it & check the timing - rev it to see if it is advancing.
Listen carefully to the exhaust - is it misfiring or still smooth?
Check the carby & see if it's still supplying sufficient fuel.
Check the accelerator cable adjustme
#5 Posted : Wednesday, 22 February 2006 8:35:02 AM(UTC)
In neutral or park it should rev its box off. In drive it won't rev past the stall speed, about 1500-1700 rpm. Take the aircleaner off and see how it goes then, sounds like a fuel/air shortage, and as it does it on both gas and petrol air is the most comm
#6 Posted : Wednesday, 22 February 2006 9:18:40 AM(UTC)
I've checked the battery and the charging system, they seem fine.
How is the "stall" activated? Is in influenced by vaccuum?
#7 Posted : Wednesday, 22 February 2006 9:36:22 AM(UTC)
A couple of minor additions to the previous posts.
100% agree with removing the air cleaner and give it a rev.
Have a mate stick his foot and the accelerator pedal while you take a look down the carby barrel with a torch and see if the throttle butt
#8 Posted : Wednesday, 22 February 2006 10:07:37 AM(UTC)
HX ute, 202 with a trimatic.
#9 Posted : Wednesday, 22 February 2006 4:15:17 PM(UTC)
A trick to test that each cylinder is getting constant spark is to put a timing light to each lead while it's idling and the when it's breaking down. Just shine the light onto a dark surface (inner guard) and see if it is strobing constantly, if the eng f
#10 Posted : Wednesday, 22 February 2006 7:24:15 PM(UTC)
Thanks guys, some good tips there.
ozjason Offline
#11 Posted : Wednesday, 22 February 2006 10:04:25 PM(UTC)
ozjason
Spud,
I had a very similar problem with my 202 after having the carby rebuilt. Drove it (very hard when I couldn't get over 40km/h) back to the carby specialist... they couldn't figure it out, and were about to pull the carby back down again when the
#12 Posted : Thursday, 23 February 2006 3:35:41 AM(UTC)
my vote is the coil...have you had the electronic ignition on this engine long? Did you upgrade the wiring to supply 12 volts to the coil? Do you have the proper HEI coil fitted.
#13 Posted : Thursday, 23 February 2006 4:19:10 AM(UTC)
The elctronic ignition was on the car when I bought it about a year ago, so anyone's guess how long it's been on there. Ran fine until now. I'll check it out by replacing a lead and see how that goes.
crowe Offline
#14 Posted : Thursday, 23 February 2006 7:58:24 AM(UTC)
crowe
Even though you have electronic ignition it still may have centrifical weights to do some advancing. Take the dissy cap off and see if the rotor arm moves against the weight springs and returns again with out any slack. some times the weights get stuck an
#15 Posted : Thursday, 23 February 2006 9:11:16 AM(UTC)
As suggested check all the leads for resistance and open circuit.
Stall speed is affected by the construction of the torque convertor from factory it is set about 1500-1700 but they can be modified to any speed, to allow for hot cams that need a high st
#16 Posted : Thursday, 23 February 2006 9:13:49 AM(UTC)
Also try revving by operating the accelerator lever on the carby fom under the bonnet. If that works then it is the cable.
#17 Posted : Thursday, 23 February 2006 9:26:57 AM(UTC)
Ur timing and points is a real good thing to look at
i had exact same problem with me hq after i put me new engine in
, but mine wouldnt rev over 2800 in drive and 3400 neutral.
i put a new coil + leads + points and corected my timing it was off its h
#18 Posted : Thursday, 23 February 2006 9:44:18 AM(UTC)
I can see Spud having a very busy few days :-)
While you're at it, fuel filter and fuel pump would be worth a check. I also have a vague recollection of fuel pick ups in the tank causing problems too. Mick, you're the spanner man, how's my memory?
#19 Posted : Thursday, 23 February 2006 10:57:49 AM(UTC)
This can also be caused by a collapsed muffler...give it a thump or two and listen for rattling noises...
Cheers...Dave
#20 Posted : Friday, 24 February 2006 10:29:29 AM(UTC)
I had a problem with my Subaru it was starving for fuel and had no power. Going up a hill in 2nd it would cough and sputter, and would not overtake anything on the open road.I replaced the fuel filter under the bonnet no help, then someone told me there w
Guest (6)
This page was generated in 0.088 seconds.
