#1 Posted : Thursday, 23 February 2006 4:17:30 AM(UTC)
hey my ed has a tapping noise just under 2000rpm when the motor is warm any body wat this is?
#2 Posted : Thursday, 23 February 2006 7:21:16 AM(UTC)
sounds like the lifters.there very small and are on the end of the rockers.i think they cost about $20 and you should change the lot if thats whats wrong,its a common problem when they do a few kms
XB351 Offline
#3 Posted : Thursday, 23 February 2006 10:47:04 PM(UTC)
XB351
1st question. What oils in it? Make sure you have the correct oil in it. Pretty sure your ED should have 15/40W. If it's got 20/50W it'll tap as you describe.
#4 Posted : Friday, 24 February 2006 12:42:15 AM(UTC)
should it be differnt oil because its done a fair few k's, not sure wat oil is in it, i had it serviced so not sure wat they stuck in it
XB351 Offline
#5 Posted : Friday, 24 February 2006 2:17:45 AM(UTC)
XB351
If oils too thick it'll cause all sorts of wear and tear as it won't drain back fast enough.
#6 Posted : Tuesday, 28 February 2006 3:21:57 AM(UTC)
hey i changed the oil to 15/40w and the noise is still there, does this mean that the lifters are screwed,
#7 Posted : Wednesday, 10 May 2006 4:00:09 AM(UTC)
Hows your oil pressure?
#8 Posted : Wednesday, 24 May 2006 10:12:26 AM(UTC)
yea oil pressure is good
