tanart Offline
#1 Posted : Thursday, 8 February 2007 12:11:13 AM(UTC)
tanart
I've been reading some material about the HK 327 and the size of the gear stick. Apparently there were 2 sizes, a short one and long one. Does anyone know the size of the long gear stick, and where these used primarily for racing? The reason i ask is that my HK 327 has a long gearstick which i've never seen on any other car. It also has the bigger valve heads (part number 3917291) which is a replacement head for the originals (part number 3917290). I'm trying to work out whether or not my car was used for racing.
#2 Posted : Thursday, 8 February 2007 12:41:07 AM(UTC)
The long one might be for the optional 4-speed on utes/vans? These had a Saginaw as standard if you ordered a 4-speed.
#3 Posted : Thursday, 8 February 2007 2:23:55 AM(UTC)
There are three Saginaw levers.
One for sedans, station wagons and base mndel Monaro
One for utes and vans
One for GTS and GTS 327
The GTS type and sedan type the only difference is the thread on the top.
The ute and van are not fitted to a con
