#1 Posted : Monday, 27 February 2006 2:58:44 AM(UTC)
This is my first time posting on fastlane and I have a couple of thing to ask.
Im currently in my HSC year at school and I'm building an EH Holden with a 179 (out to 192) and i wat to go 3speed. Currently my EH Has a 202 this a aussie 4 speed behind it (M20). Peope ask why i want to go back to three, i say i like things original...
Is it possable to put a HQ 3 speed box in an EH and make it a collum shift? I wanted the HQ box because is all syncro. I've been told i can't because the linkages are too diffrent but i want other peoples opinions.
I'll appreaciate and feedback.
Aaron
EH - Stands for "Extra Horses"
peter_flane Offline
#2 Posted : Monday, 27 February 2006 3:14:15 AM(UTC)
peter_flane
Anything is possible, however the linkages are different and they do not fit. In 15 years of hanging around EH owners and being in the scene I have never seen a single EH with a 3 speed all synchro fitted. Maybe for a reason. Bolts up easy, cheap to get,
#3 Posted : Monday, 27 February 2006 7:42:14 AM(UTC)
Thanx Peter.
Would anyone know if putting in another collum is a possibility or would it be easyer just to go but to a crash box? I want to steer clear of floor shifters i want collum shift!!!
EH - Stands For "Extra Horses"
peter_flane Offline
#4 Posted : Monday, 27 February 2006 9:31:24 AM(UTC)
peter_flane
This is where you are starting to not make much sense. You say you like things original! Changing gearboxes and columns is not original, so just put the crash box back in it and drive sedatley. The crash box may well give you 20 years of service. There yo
#5 Posted : Monday, 27 February 2006 9:42:42 AM(UTC)
I agree with Peter. If you want to keep it original (and I applaud you for it because I like keeping cars as original as possible too) change to a trimatic with column auto. Unless people get underneath they won't know the difference, plus it will fit whe
FastEHHolden Offline
#6 Posted : Monday, 27 February 2006 10:05:31 PM(UTC)
FastEHHolden
I had a 3 speed syncro box fitted to my EH..floor shift...I actually find if you had the horsepower they were quicker...2nd gear is awesome.
My guess is that yours is an auto body..as a 4 speed in a manual body is a bit of a squeeze.
I think you cou
#7 Posted : Tuesday, 28 February 2006 6:20:07 AM(UTC)
I know I said I wanted original and I'm doing my best top keep it original.
HR Disc Brakes are already on my car (there staying for safety and they stop on a dime!) I want collumn shift cause its original, people shake there heads at me but thats what
#8 Posted : Wednesday, 1 March 2006 8:07:55 AM(UTC)
Aaron,
where abouts are you? I am in Brisbane, i know a few tricks about putting a 3 speed syncro box into an EH, as my last EH sedan had 3 speed synco box in it.
Give me a call on 0411 600 693 if ya want to have a chat
#9 Posted : Wednesday, 1 March 2006 9:35:12 AM(UTC)
FastEHHolden
He he..stop on a dime...hr brakes make them stop..not on a dime..but they stop...drum brakes you just sail straight past your dime.
Good luck with your project.
#10 Posted : Saturday, 4 March 2006 3:29:03 AM(UTC)
Not sure how the powerglide and trimatic measure up for size but i put a powerglide in my EH wagon was a manual 3 speed before, had to drastically modify the floor pan because the glide was too big.
Maybe try putting a auto floor pan in might work.
Colu
#11 Posted : Saturday, 4 March 2006 11:41:43 PM(UTC)
Les i'm in Wollongong. So i'm abit of a distance from you.
However my dad works in Brisbane afew times a month.
I'll give you a call sometime this weekend if u don't mind.
Thanx for offering some advice, i'll speak to you soon.
#12 Posted : Monday, 8 May 2006 8:07:51 PM(UTC)
Floor shift 3 speed is really easy conversion and, maybe, practicality might win over originality here? And, an all synchro box is not 'original'!
I put a floor shift in an EH years ago (original box) because it was cheaper than continually fixing the co
#13 Posted : Wednesday, 10 May 2006 6:27:22 AM(UTC)
hey arron , i agree with pete , put the crash box back in it ,drive it nicely and all should be well , but maybe and i dont know you could set up a 3 speed syncro box .. custom make some linkages , anything is possible
x
#14 Posted : Friday, 12 May 2006 11:27:19 AM(UTC)
You won't be able to make up linkages to work as the two boxes use entirely different methods of selection. The crash box uses the same lever to select reverse/first or 2nd/3rd and the other lever selects which action the first lever is to perform. The
#15 Posted : Monday, 15 May 2006 5:20:35 AM(UTC)
Jeff, I may be interested in the 3 speed shifter, what else would I need? How are the gears organised i.e. 1st > 2nd > 3rd, as I've heard they are all arse about with a crashbox & floorshift.
Cheers.
Edited by user Monday, 15 May 2006 5:23:21 AM(UTC)  | Reason: Not specified
Guest (10)
