#1 Posted : Friday, 3 March 2006 7:47:32 AM(UTC)
I own a '95 EF Futura, 4L, Auto. Six months ago, the car began to 'stutter' whilst going up hills. The problem went away for a month, then returned. This 'stuttering' feels like a drop out of power, then re-ignition. When at idle, the engine appears to drop in RPM and then pick back up... Whilst running, it feels like I am 'pig rooting' (an auto!!!)
The kicker, I have now replaced everything from the plugs to the EFI. Injectors have been cleaned and Auto Elecs can't work it out...
Has anyone else out there ever experienced this type of mechanical problem? Is it the 4.0 DOHC engine? Please HELP before more money than the car is worth gets put into the hands of an inept mechanic professing he can locate it...
Munromad2004 Offline
#2 Posted : Friday, 3 March 2006 8:31:41 AM(UTC)
Munromad2004
I had a very similar problem on my EA.
It was the wire on the negative side of the coil earthing out.
It was damn hard to find as it is tucked away under the intake manifold and it's a black wire hidden in a geasy engine bay.
At idle it would tou
Paul351xb Offline
#3 Posted : Friday, 3 March 2006 9:53:40 AM(UTC)
Paul351xb
Another wire to check is the one coming off the dizzy. It sits between the dizzy and the block and cooks over time making the wire brittle even though it may look OK from the outside.
#4 Posted : Friday, 3 March 2006 10:42:24 PM(UTC)
Munromad2004
Actually now you mention it, I do believe that was actually the wire that caused the problem on mine.
It was a couple of years ago.
#5 Posted : Saturday, 11 March 2006 6:21:37 AM(UTC)
Thanks for the feedback gents. If nothing else, I am now more confident in advising the next mechanic what past problem people have experienced and may even narrow done the search. Once again, thanks for your feedback. It is greatly appreciated.
#6 Posted : Sunday, 9 April 2006 8:42:56 PM(UTC)
hi there, I was was wondering if anyone has any chrome 3'' ladder racks and sports bar for a au ute series2, thanks Tony.
#7 Posted : Monday, 17 April 2006 6:16:52 AM(UTC)
I presume you've changed to feul filter?? ours did the same and that's all it was.
#8 Posted : Monday, 17 April 2006 8:57:02 AM(UTC)
Ignition coil and plug leads r common on these cars from what u r saying. The RPM drop and rise problem sounds like a vacume leak or map sensor problem. check the inlet manifold gasket has not split and causing a vacume leak.Is there a rushing air noise a
