#1 Posted : Saturday, 4 March 2006 2:47:46 AM(UTC)
G'day Guys,
I have '76 HX Ute, and the wipers no longer work.
I was working in that area at the time, so i mite have stuffed something, this is what I did:
* Took Wiper Grill (under windscreen) off, to install a finer mesh behind it (I park under a Jackaranda (spel?) so the plenum fills with crap...)
* Fitted grill, had to go to work, forgot to put one wiper back on, started to rain, turned wipers on, the one that was still connected moved a little bit then stopped......
* Since then, nothing has happened at all..... motor doesnt appear to be trying to turn, will check for voltages at the motor plug.
* Also, last couple of days Ive noticed that the Wiper Stalk has been warm to the touch! is this normal? or should I pull the wheel off and look for a short........
* Thanks guys!
1976 HX Ute 308
#2 Posted : Saturday, 4 March 2006 3:48:57 AM(UTC)
Hey guys,
I put a multimeter on the four prong plug that connects to the wiper:
Yellow: 12v
Black: Ground
Light Blue: no voltage, but doubt its grounded
White: no voltage, but doubt its grounded
This was done when i had the switch set to low s
#3 Posted : Saturday, 4 March 2006 5:24:32 AM(UTC)
Dont blame you guys for not being able to solve this one. I sorted it out....
Fixed it all with another 18cm ring of MDF.
which brings me to my next question, anyone else ever tried to mount 6.5 inch speakers where the heater ducting used to be, hen
