#1 Posted : Tuesday, 7 March 2006 11:06:49 PM(UTC)
One day my ute was going fine the next it is spitting fuel out of the carby. i've been told many things (timing, needle and seat coil etc etc) Has anyone encountered this problem and how to fix
UNRULY Offline
#2 Posted : Tuesday, 7 March 2006 11:10:21 PM(UTC)
UNRULY
Where was the fuel coming from? Most of the time it is either a blocked needle and seat, or too much fuel pressure.
#3 Posted : Tuesday, 7 March 2006 11:22:22 PM(UTC)
it's coming out of the top of the carby where the air filter sits on top. The needle & seat look fine (my opinion)
UNRULY Offline
#4 Posted : Wednesday, 8 March 2006 8:16:57 PM(UTC)
UNRULY
It is a Holley or a quadrajet. If its a holley, try adjusting the float levels.
#5 Posted : Thursday, 9 March 2006 10:46:01 AM(UTC)
what engine are you running?
#6 Posted : Thursday, 9 March 2006 9:16:39 PM(UTC)
Its a 350 Holley and I've tried to adjust the float levels and fuel keeps coming out of the hole on the side its a 253
#7 Posted : Thursday, 9 March 2006 11:50:34 PM(UTC)
Once you have fuel coming out the side, you know your float is set - tighten your nut up and put the bolt back in! I've got a 350 holley that used to do that and its not float level (mechanic wouldnt tell me what it was back then!!).
Keith
[img]http:
