#1 Posted : Monday, 12 February 2007 8:46:05 PM(UTC)
Has anyone successfully done this conversion? Can you use the VN wiring harness, computer and coil pack? Are there any issues with the VN gearbox being used. Thanks.
#2 Posted : Monday, 12 February 2007 10:26:16 PM(UTC)
If it's auto, no probs.
If it's manual, early VNs are unsuitable (different crank & flywheel).
If it's an early VN you'll need to extend the wires for the coolant temp sensors. You'll also need to replicate the VR cooling system into it.
If it's a
#3 Posted : Wednesday, 14 February 2007 2:19:26 AM(UTC)
I believe that you can also use the VR coil packs & DFI module as they are reputedly better than the earlier ones. (Commonly the whole assembly of the three coil packs & the DFI module is mistakenly referred to as the coil pack)
#4 Posted : Wednesday, 14 February 2007 4:44:58 AM(UTC)
That's correct Jim - the VN coil pack is a 1 piece unit, where the VR ones are 3 individual coils.
They are plug & play into a VN as long as you have the the whole assembly, ie, the coils + the DFI module that sits under the coils.
