GMH1975 Offline
#1 Posted : Thursday, 9 March 2006 3:28:37 AM(UTC)
GMH1975
Hi im thinking of buying a harrop manifold to suit efi heads on a 308.
My engine is an hsv enhanced 308 with approx 185kw and t700 trans.
would i be better off with a single plain or duel plain manifold ?
Not the BLOODY Kingswood
#2 Posted : Thursday, 9 March 2006 5:37:33 AM(UTC)
Cam, exhaust, carby, gearing, car, driving?? The answer will depend upon all these questions and more.
CherryBomb Offline
#3 Posted : Thursday, 9 March 2006 8:21:42 AM(UTC)
CherryBomb
Tp be short and sweet about it:
A single Plane Man will push the Torque curve up, And in return be doughy down low. Not recommended for a daily street car!
A dually will increase the incoming charge, And in return be more user friendly for the Stree
Never stop being inspired,
GMH1975 Offline
#4 Posted : Friday, 10 March 2006 2:39:44 AM(UTC)
GMH1975
BYRON
Cam ....no idea
Exhaust.........vn manfolds and single 2 1/2 inch system
Carby.........fuel injected
gearing..........turbo 700 and 3.08 gears in the ass end
Car ..........HX Kingswood sedan
Driving...........I have a heavy right foot
Not t
#5 Posted : Friday, 10 March 2006 4:13:57 AM(UTC)
If it's fuel injected why not use the Holden valley? You would only need a single or dual plane Harrop valley if you were looking to run a carby. If that were the case I'd buy a dual plane and run a sorted quadrajet.
GMH1975 Offline
#6 Posted : Friday, 10 March 2006 5:10:11 AM(UTC)
GMH1975
Im thinking of running airconditioning and i cant do it with the bunch o bannanas setup because the inlet tube is in the way
CherryBomb Offline
#7 Posted : Friday, 10 March 2006 5:46:09 AM(UTC)
CherryBomb
Do Harrop even make a Duel plane yet?......... The Singles aint that Low either! There a Higher placed than normal Manifold.
Active Auto made a Low level EFI Manifold a few years back with Dual TB at the front, Looked tough, And performed well.
COM
GMH1975 Offline
#8 Posted : Friday, 10 March 2006 6:14:12 PM(UTC)
GMH1975
Harrop do have a duelplain acording to thier website.
Harrop aint cheap but COME id have to mortgage the house LOL.
Anyone else make aftermarket manifolds for the efi heads?
#9 Posted : Friday, 10 March 2006 6:48:17 PM(UTC)
Redline now have John Cain's old moulds and make a dual plane valley to suit a carby, but it has bosses for injectors I think. You just use a 4-barrel throttle body in place of the carb.
GMH1975 Offline
#10 Posted : Friday, 10 March 2006 7:06:06 PM(UTC)
GMH1975
But are they made for efi or non efi head?
#11 Posted : Saturday, 11 March 2006 10:20:45 PM(UTC)
A dual plane manifold would be better but there are a few catches. You will need to modify your injection harness slightly as some of the sensors will be in a different position (throttle position, idle motor). You will also have to drill and tap a hole i
GMH1975 Offline
#12 Posted : Saturday, 11 March 2006 11:36:46 PM(UTC)
GMH1975
Matt is it possible to put the alternator on the drivers side if i have power steering?
would you be able to send me some pice etc of the mounts you have made?
This page was generated in 0.128 seconds.
