Hi im thinking of buying a harrop manifold to suit efi heads on a 308. My engine is an hsv enhanced 308 with approx 185kw and t700 trans. would i be better off with a single plain or duel plain manifold ?
Not the BLOODY Kingswood |
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
Cam, exhaust, carby, gearing, car, driving?? The answer will depend upon all these questions and more. |
Tp be short and sweet about it:
A single Plane Man will push the Torque curve up, And in return be doughy down low. Not recommended for a daily street car!
A dually will increase the incoming charge, And in return be more user friendly for the Stree |
Never stop being inspired, You may never realize your full potential. |
BYRON Cam ....no idea Exhaust.........vn manfolds and single 2 1/2 inch system Carby.........fuel injected gearing..........turbo 700 and 3.08 gears in the ass end Car ..........HX Kingswood sedan Driving...........I have a heavy right foot
Not t |
If it's fuel injected why not use the Holden valley? You would only need a single or dual plane Harrop valley if you were looking to run a carby. If that were the case I'd buy a dual plane and run a sorted quadrajet. |
Im thinking of running airconditioning and i cant do it with the bunch o bannanas setup because the inlet tube is in the way
Do Harrop even make a Duel plane yet?......... The Singles aint that Low either! There a Higher placed than normal Manifold.
Active Auto made a Low level EFI Manifold a few years back with Dual TB at the front, Looked tough, And performed well.
COM |
Harrop do have a duelplain acording to thier website. Harrop aint cheap but COME id have to mortgage the house LOL. Anyone else make aftermarket manifolds for the efi heads?
Redline now have John Cain's old moulds and make a dual plane valley to suit a carby, but it has bosses for injectors I think. You just use a 4-barrel throttle body in place of the carb. |
But are they made for efi or non efi head?
A dual plane manifold would be better but there are a few catches. You will need to modify your injection harness slightly as some of the sensors will be in a different position (throttle position, idle motor). You will also have to drill and tap a hole i
Matt is it possible to put the alternator on the drivers side if i have power steering? would you be able to send me some pice etc of the mounts you have made?
