#1 Posted : Saturday, 11 March 2006 7:16:06 AM(UTC)
Where is the best spot to put a baby seat bolt on the rear shelf of my LH torana. thanks
GMH1975 Offline
#2 Posted : Saturday, 11 March 2006 6:21:34 PM(UTC)
GMH1975
You should have a hole there allready.
Have a look from inside the boot and see if you have 3 nuts welded to the parcel shelf (1 in the middel and 1 on each side).
If you dont the best way would be to drill a hole in the middle of the shelve and get a p
Not the BLOODY Kingswood
#3 Posted : Saturday, 11 March 2006 9:53:02 PM(UTC)
thanks gmh1975. no bolts there, but will do as you say and put one in! selling the mazda 3 and upgrading to the torana to save some money. m0
#4 Posted : Wednesday, 15 March 2006 7:52:43 AM(UTC)
Go to Repco and buy the kit $14.00-20.00. It will give you the correct size plate 75x75x3mm that is required and will also give you the adapter from old to new style capsule and seat hooks. Do not mount it near where you have mounted speakers, judge for y
Guest (5)
This page was generated in 0.097 seconds.
