#1 Posted : Tuesday, 13 February 2007 11:11:46 PM(UTC)
Chaps,
I have a XC FAirmont (250 + auto) that I would like to convert to a 351 + manual trans.
How hard is it? What bits do I need? I have no idea what diff is in it, 6 cyl one..if I fit a 9" then what about 4 wheel disks ? Can I leave the stock master/booster etc? Are the V8 sumps different between the different Ford models?
I'm mainly a holden man so I'm a bit in the dark.
Any help greatfully appreciated.
Paul351xb Offline
#2 Posted : Wednesday, 14 February 2007 6:22:12 AM(UTC)
Paul351xb
Best thing I can suggest is find an old rusted XC or ZH and transfer the running gear over. It works out a lot cheaper in the long run. All the Clevo sumps are the same. To do the swap, including the 9 inch disc rear you will need, engine mounts, new g
