Hi, I have what I beleive to be a fully optioned WB panel van. I would like to verfiy this somehow but after ringing Holden just then I dont think it will be possible. They said they only keep records for approx the last 10 years giving vehicle information such as option codes. They also said that they can do an authenticity check but only for Monaros/Sandmans etc in the 70s. The guy said definately not WB.
Does anyone know if there is any other way to find out information, whether it be locating the original dealer and seeing if they have records etc. All the information on the tag matches up but would like to find out more.
Any ideas greatly appreciated! Rhys
Hi Rhys.
The best thing is to post all your numbers,i.e. Chassis, Engine, Body Plate Details, VIN Plate details & Compliance Plate details. From that we can tell what your car should be.
It this of course, depends on what you mean by the term fully |
Hi Rhys.
It this of course, depends on what you mean by the term 'fully |
Thanks Given: Was thanked: 615 time(s) in 582 post(s)
Agree with Dr Terry. A 'fully' optioned WB panel van in my 'way of thinking' would be:
HOLDEN (nee Belmont), 308, M38/M40, power steer, air, GTS dash, buckets, alloy wheels (N67 aka HZ SL/E, late HZ GTS, Sandman etc), intermittent wipers, metallic pain |
Agree with Dr Terry. A fully optioned WB panel van in my way of thinking would be:
HOLDEN (nee Belmont), 308, M38/M40, power steer, air, GTS dash, buckets, alloy wheels (N67 aka HZ SL/E, late HZ GTS, Sandman etc), intermittent wipers, metallic paint, L |
Thanks Dr Terry and Byron. Numbers are as follows:
03/82 CWB31734A GVM 2200KG SEATING CAP 2
8M70RB L549561B
MODEL WB8WM70 BODY NO 549561-A TRIM 1989-67V PAINT 1D-005-B BUILT MAR 82 ENG L36 TRANS M40 RRAXLE GV7
Its Cameo Yellow in colo
8M70RB L549561B
It's Cameo Yellow in col
Fully optioned alright. About the only thing missing is a 308, which was not officially a normal option but I have seen WBs with a factory 308 and metallic paint (which may not have been available on a Belmont). Its a 253 trimatic with 3.55 as you say. Th |
Fully optioned alright. About the only thing missing is a 308, which was not 'officially' a normal option but I have seen WB's with a factory 308 and metallic paint (which may not have been available on a 'Belmont'). It's a 253 trimatic with 3.55 as you s |
Hi People This is an interesting topic, as I have owned WB's predomatly all my life ,I would like to try and learn a little more about the options myself. Dr Terry seems to have some excillent info so I may be bothering him a lot in the future. I have wh
Hi People This is an interesting topic, as I have owned WBs predomatly all my life ,I would like to try and learn a little more about the options myself. Dr Terry seems to have some excillent info so I may be bothering him a lot in the future. I have wha
A mate has a 1983 WB ute with a factory optioned GTS dash and buckets his ID tags read as a 308 T400.
Can't read as a TH400 (M41) as no WB was ever fitted with one. If it's a pre 1982 and 308 it will read M38 (TH350). Lter examples will be M40 (trimatic). |
Cant read as a TH400 (M41) as no WB was ever fitted with one. If its a pre 1982 and 308 it will read M38 (TH350). Lter examples will be M40 (trimatic). |
Thanks for the tips guys. Holden HX LE if you could find that WB options sheet and send me a scan that would be great.
Byron I've seen an original '82 WB Van with a factory Tahitian (metallic grey/blue) paint job so I guess there were a lot of special
Byron Ive seen an original 82 WB Van with a factory Tahitian (metallic grey/blue) paint job so I guess there were a lot of special o
Thanks: 1 times Was thanked: 35 time(s) in 33 post(s)
^^ While on the same topic Rhys, theres a Tahitian WB 1-tonner near my place. Again, the right code is on the tag & all.
It caught my attention as it is a VH Commodore colour (particularly SL/Es & Shadowtone cars).
Mick ________________ |
^^ While on the same topic Rhys, there's a Tahitian WB 1-tonner near my place. Again, the right code is on the tag & all.
Mick _______________ |
hi i have just purchased a 308 and auto the auto is supposed to be a th350 how can i tell the selector arm is on the right side if looking front on and i am told was in a vl commodore cheers aussie chris
