#1 Posted : Thursday, 16 March 2006 1:48:29 AM(UTC)
I have heard of this in reference to diff gears etc.
What is it and why is it done??
DaMiEn Offline
#2 Posted : Thursday, 16 March 2006 5:00:29 AM(UTC)
DaMiEn
Lapping is a process in which a soft cloth impregnated with abrasive pastes or compounds is rubbed against the surface of a workpiece. Lapping is used to produce a high-quality surface finish or to finish a workpiece within close size limits. Dimensional
FastEHHolden Offline
#3 Posted : Saturday, 18 March 2006 3:19:01 AM(UTC)
FastEHHolden
in the case of diff gears they are driven with an abrasive paste between the teeth and they "wear" to each other...it cuts down noise and basklash will remain consistant as the gears wear...they do it because the machining process is not perfect..lapping
