wimjack Offline
#1 Posted : Friday, 16 February 2007 9:18:30 PM(UTC)
wimjack
Hey Guys
I just Picked up a second hand window and I need to remove the aftermarket tint film thats on it.
What is the easiest way to get it off?
Cheers Jack
#2 Posted : Friday, 16 February 2007 10:45:13 PM(UTC)
If it's a side window ie no rear demister the best way is to peel the tint then scape the glue off with one of those scrapers that takes razor blades then metho & a rag or if your brave metho & some coarse steel wool.
A steamer usually used to rem
#3 Posted : Saturday, 17 February 2007 4:44:09 AM(UTC)
Alternatively, lay the window down and cover with wet newspaper for about ½ an hour to an hour (if the weather is hot, you may need to re-wet the newspaper).
Then peel the tint off and clean up as Jim said above.
Cheers...Dave
Edited by user Saturday, 17 February 2007 4:45:17 AM(UTC)  | Reason: Not specified
#4 Posted : Saturday, 17 February 2007 7:35:22 AM(UTC)
Use steel wool if you like scratched glass.
The other ideas work well enough.
#5 Posted : Tuesday, 20 February 2007 3:09:53 AM(UTC)
John coarse scourers wont scratch the glass if you are carefull ie don't press too hard but I do agree with you on the steel wool issue. Those green plastic scourers are the worst for scratching glass.
Sorry if I mislead you on the steel wool issue I m
HarryO Offline
#6 Posted : Tuesday, 20 February 2007 6:24:58 AM(UTC)
HarryO
Hi Guys. Picked this up from a site yesterday, knew it would be useful eventually!
Removing old window tint-: First bits easy, peel up an edge with a razor blade & rip the film off!!...now that darn glue is still stuck to the glass!!
Use a new blade t
landy351 Offline
#7 Posted : Thursday, 22 February 2007 5:38:48 AM(UTC)
landy351
Hi I used to work for a windscreen fitting company and was across the road from the motor registration branch who sent us all there defected for tint cars .
The easiest way we found Was (as Stated) peel an edge then use a new (save on scratches)single ed
Paul351xb Offline
#8 Posted : Thursday, 22 February 2007 5:56:19 AM(UTC)
Paul351xb
Here's a little tip you might all like to know. With gooey stuff on glass try using eucalyptus oil and a clean cloth. This works great for getting the last of the sticky stuff off.
