#1 Posted : Saturday, 17 February 2007 2:34:25 AM(UTC)
does anyone know were to get heat wrap in the newcastle nsw area ? i need it because the heat of my extractors stops the starter from working on my hq im hoping heat wrap will fix the problem cheers
#2 Posted : Saturday, 17 February 2007 7:47:21 AM(UTC)
I have a new roll of heat wrap used for insulating fuel lines I presume it would work on the starter.
Retails around $45, you can have it for $18 plus postage, probably cost about $5 for postage.
Sandman Offline
#3 Posted : Saturday, 17 February 2007 7:36:09 PM(UTC)
Sandman
Are you planning on wrapping the extractors or starter motor? If you wrap the extractors the will rust out a lot easier.
Do you run a relay to the starter motor. The soleniods in chev starters seem to draw more current than a Holden ignition switch is ha
#4 Posted : Saturday, 17 February 2007 10:12:30 PM(UTC)
Wrapping the exhaust will cause it to rust out quicker but I guess you have to balance it against the convenience of not getting your hand burnt off everytime you go near the pipes and there is a belief you get a bit more power with the pipes really hot.
Sandman Offline
#5 Posted : Sunday, 18 February 2007 3:00:41 AM(UTC)
Sandman
I have always just used a 30 amp Hella relay for my starters and have never had one die on me in near 30 yrs of running chevs. In fact, I use the same style relays for most added in electrics, fans, fuel pumps, nitrous etc, as the wiring and switches in o
Mr Void Offline
#6 Posted : Sunday, 18 February 2007 5:57:52 AM(UTC)
Mr Void
As an easy fix, if it is a heat related issue, I would go with Sandman's heat shield suggestion. Having worked in the insulation industry for a number of years I know that they work very well.
Just make sure there is a piece of sheet metal (the more ref
___________________
#7 Posted : Sunday, 18 February 2007 6:35:04 AM(UTC)
VN-VP V8's use a heat shield on the same old 253/308 starter. Air is one of the best heat insulators you can get - you just need a heat barrier with air between it and the part to be protected, hence Mr Void's and Sandman's recommendations. I used to work
#8 Posted : Tuesday, 20 February 2007 2:16:26 AM(UTC)
the starters on a 202 i was going wrap the extractors near the starter but know i might try a heavier wire and a heat metal heat shield im still able to bridge the starter to fire up in extream cases seams the heavier cable will be the way to go thanks f
jabba Offline
#9 Posted : Tuesday, 20 February 2007 4:04:16 PM(UTC)
jabba
A remote starter solenoid is also MOST useful. My 400 chev used to bind up something terrible when warm, and even a high torque starter used to struggle.
Wiring is usually battery + to starter, with big wire taking power from there to fuse box. Small wi
