5 Pages<12345>
#41 Posted : Wednesday, 23 May 2007 6:11:09 AM(UTC)
I hadnt.
#42 Posted : Wednesday, 23 May 2007 6:11:09 AM(UTC)
I hadn't.
Mr.Jones Offline
#43 Posted : Thursday, 24 May 2007 8:42:30 AM(UTC)
Mr.Jones
Byron I have a VQ Statesman engine with a SVU prefix, I see you dont have it on your list.
Cheers Leroy
Voltaire
Mr.Jones Offline
#44 Posted : Thursday, 24 May 2007 8:42:30 AM(UTC)
Mr.Jones
Byron I have a VQ Statesman engine with a SVU prefix, I see you don't have it on your list.
Cheers Leroy
Voltaire
#45 Posted : Thursday, 24 May 2007 5:18:36 PM(UTC)
That's new to me. I wonder if it's the same principle as 11 or 12 prefixes for HQ-WB Statesman engines ie S meaning Statesman? This would mean an SVM should also exist. I wonder if that means that there are GenIII's with SVF prefixes?
Can anyone also giv
Edited by user Thursday, 24 May 2007 5:24:30 PM(UTC)  | Reason: Not specified
#46 Posted : Thursday, 24 May 2007 5:18:36 PM(UTC)
Thats new to me. I wonder if its the same principle as 11 or 12 prefixes for HQ-WB Statesman engines ie S meaning Statesman? This would mean an SVM should also exist. I wonder if that means that there are GenIIIs with SVF prefixes?
Can anyone also give m
#47 Posted : Thursday, 24 May 2007 5:54:45 PM(UTC)
Hi Guys.
VU is the normal 5.0-litre EFI V8 & SU is the Genuine parts replacement block. I wonder if it's a mis-stamping or an early version of the replacement number series, perhaps combining both prefixes.
Do you have the original owners manual, is
#48 Posted : Thursday, 24 May 2007 5:54:45 PM(UTC)
Hi Guys.
VU is the normal 5.0-litre EFI V8 & SU is the Genuine parts replacement block. I wonder if its a mis-stamping or an early version of the replacement number series, perhaps combining both prefixes.
Mr.Jones Offline
#49 Posted : Saturday, 26 May 2007 9:06:59 PM(UTC)
Mr.Jones
Dr. Terry I bought the engine from a wreckers for my Monaro. They told me it came form a VQ Statesman. The engine no. is SVU613051, the stamp on the heads are 10M2, and it has 5.0L on both sides of the block havent seen that before, but havent had much
Voltaire
#50 Posted : Sunday, 27 May 2007 1:13:06 AM(UTC)
I have a VQ statesman owner manual and the engine number in it is VU589882 first rego in 6/90
So this would indicate that the Statesman did not have S in the engine number, but theory is worth investigating considering the model code in the VIN is VS
#51 Posted : Sunday, 27 May 2007 1:27:55 AM(UTC)
I've never seen an SVU prefix before, only VU, and in a VT I've seen SM###### instead of the usual VM###### - indicating what Terry has noted - that spare part EFI blocks are S*###### prefix
____________________________________________
#52 Posted : Sunday, 27 May 2007 1:27:55 AM(UTC)
Ive never seen an SVU prefix before, only VU, and in a VT Ive seen SM###### instead of the usual VM###### - indicating what Terry has noted - that spare part EFI blocks are S*###### prefix
______________________________________________
#53 Posted : Friday, 29 June 2007 8:14:27 AM(UTC)
Has anyone ever heard of a 186 engine number like this one: 186N1978S I saw it today, it looks original. Any ideas on what car it was originally in? It is now in an EH.
#54 Posted : Friday, 29 June 2007 4:13:19 PM(UTC)
My guess is a Nasco replacement 186 short motor. Im not sure how they distinguished between high and low compression though if Im right. Are you sure the suffix is S?
If we all had the same (good
#55 Posted : Friday, 29 June 2007 4:13:19 PM(UTC)
My guess is a Nasco replacement 186 short motor. I'm not sure how they distinguished between high and low compression though if I'm right. Are you sure the suffix is S?
#56 Posted : Monday, 9 July 2007 2:29:28 AM(UTC)
Checked it, cleaned it off with a wire brush and checked again. Definately an "S" on the end - 186N1978S
#57 Posted : Monday, 9 July 2007 6:42:28 PM(UTC)
any one know the story about 3 rib 202 block. VL prefix.
#58 Posted : Monday, 9 July 2007 9:24:22 PM(UTC)
VL prefix is simply VB-VK Carby 202, in red, black & blue.
The actual number will give more of a clue to the era it's from, if you can't find the casting date.
A lot o
#59 Posted : Monday, 9 July 2007 9:24:22 PM(UTC)
The actual number will give more of a clue to the era its from, if you cant find the casting date.
A lot of
#60 Posted : Saturday, 14 July 2007 9:49:30 PM(UTC)
why 3 ribs on block. driver side behind oil filter? it had 202 on the block not 3.3 . after prefix only had xxxx 4 numbers.
5 Pages<12345>
This page was generated in 0.083 seconds.
