#1 Posted : Sunday, 18 February 2007 1:10:05 AM(UTC)
about to replace carpet in hz wagon. but before doing so, what are the best solutions to reduce the heat from transmission and motor creeping into car..? is there a certain type of underlay or heat reduction products etc, or something similar that will reduce the temperature inside the car.
cheers geoff
Mr Void Offline
#2 Posted : Sunday, 18 February 2007 5:59:44 AM(UTC)
Mr Void
Where abouts are you geoff? There are a couple foam products out there that will also cut some of the noise down too..
___________________
Why are you reading this, you should be looking up there^^
Joetech Tonner - coming soon!
___________________
#3 Posted : Sunday, 18 February 2007 8:12:50 AM(UTC)
gold coast
JBM Offline
#4 Posted : Sunday, 18 February 2007 8:23:48 AM(UTC)
JBM
If youve ever seen OverHaulin they use something for insulation for heat and sound but Im not sure what its called. Will try to find out for you.
James
You only have to be in front at the end
T-note Offline
#5 Posted : Sunday, 18 February 2007 7:37:09 PM(UTC)
T-note
is it dynamat?
#6 Posted : Sunday, 18 February 2007 8:19:34 PM(UTC)
Yes it is. It's a bitumen/foil mat
#7 Posted : Sunday, 18 February 2007 10:43:47 PM(UTC)
this is going to sound stupid - but does the dynamat go under the carpet or is it fitted under car - like i said its a stupid question but im not 100% sure
cheers geoff
Mr Void Offline
#8 Posted : Sunday, 18 February 2007 11:22:43 PM(UTC)
Mr Void
If you go to P.J.Bowers at 5 Central Drv Burleigh Heads (or give them a call on 5593 8277) ask them for a some 10 or 15mm thick 'NSL'. It comes 1m wide, hopefully if you get them on a good day they'll give you some off cut, or it'll cost you ~$20 for a p
Edited by user Sunday, 18 February 2007 11:24:47 PM(UTC)  | Reason: Not specified
___________________
JBM Offline
#9 Posted : Monday, 19 February 2007 1:34:49 AM(UTC)
JBM
Originally posted by T-note
is it dynamat?
