wimjack Offline
#1 Posted : Tuesday, 28 March 2006 3:38:08 AM(UTC)
wimjack
Hey Guys
I have just upgraded the brakes on my Xb Falcon to Xd Discs.Ive changed over the mastercylinder, booster and all lines.Im having trouble getting the air out of them.Ive followed the manual on how to bleed them but nothing seems to be happening, the resevoir is still remaining full. Any advice would be muchly appreciated.
Cheers Jack
This is Ford Country
Paul351xb Offline
#2 Posted : Tuesday, 28 March 2006 5:28:03 AM(UTC)
Paul351xb
Have you loosened the bleeder screw on the calipers? Are you using a bleeding tool?
wimjack Offline
#3 Posted : Tuesday, 28 March 2006 5:33:04 AM(UTC)
wimjack
Yep push down on brake pedal, Loosen screw, Tighten screw, Release brake pedal.
#4 Posted : Tuesday, 28 March 2006 7:15:23 AM(UTC)
Try using a piece of vacuum hose about 300mm long,open bleeder connect hose to bleeder and drop other end into a bottle or similar,
then pump until fluid comes out keeping master cyl full this always works.
if it ain't broke we can improve it.
Ch
wimjack Offline
#5 Posted : Friday, 31 March 2006 3:01:24 AM(UTC)
wimjack
I finally found the problem,
After pulling apart the lines there were a couple of blockages.
I cleaned them out and now its all working fine.
Thanks for the help!
Cheers Jack
