#1 Posted : Wednesday, 29 March 2006 1:02:57 AM(UTC)
I am experiencing a vibration in my 1990 VQ Statesman 5.0 litre. Appears to be from the trans or tailshaft - has only just started. Its most noticable at about 3,000 rpm in 2nd gear but can be felt at low revs just off idle in 1st gear. Could it be a universal joint on the way out? Any ideas?
tanart Offline
#2 Posted : Wednesday, 29 March 2006 2:13:52 AM(UTC)
tanart
Could also be the centre tail shaft bearing. They usually need replacing after a while.
#3 Posted : Wednesday, 29 March 2006 2:44:46 AM(UTC)
Thanks Tanart, will get it checked out - would you know how much it would cost to replace the centre tail shaft bearing?
jabba Offline
#4 Posted : Wednesday, 29 March 2006 10:11:37 PM(UTC)
jabba
Am going through this with VN Exec.
Lowered suspension (if fitted) changes driveshaft angles, and universals & centre bearing play up.
Engine mounts perishing.
Trailing arm / diff mounts.
Plugs / leads.
Steering play.
Failing all of that (which
#5 Posted : Thursday, 30 March 2006 11:40:46 PM(UTC)
Thanks Jabba, I'm really hoping my problem is not transmission related.
I had a similiar problem with a VN Berlina 5.0 litre auto with FE2 which I bought new in 1990. It would vibrate very badly in first gear under heavy acceleration. After much muck
DaMiEn Offline
#6 Posted : Friday, 31 March 2006 6:13:18 AM(UTC)
DaMiEn
ur best bet is a uni joint if they are gone u will feel a hell of a vibration and also a lot ok noise
#7 Posted : Friday, 31 March 2006 9:19:22 PM(UTC)
There is an advisory out on the NSW RTA web site saying that rego inspection places should pay particular attention to the cross member that holds the differential up (they crack) on IRS Holdens. Especially on 5 litre manual cars.
Maybe you should chec
Edited by user Friday, 31 March 2006 9:42:18 PM(UTC)  | Reason: Not specified
Guest (6)
