HarryO Offline
#1 Posted : Tuesday, 20 February 2007 6:31:41 AM(UTC)
HarryO
Hi. Wondering if anyone could brainstorm a problem..
When I turn left in my EJ ute at low speed(std diff), makes a clunk clunk sound. Almost positive it is at the rear, but you know how it is with cars..
All nuts tight on the wheel and shaft to diff bolts fine. Internals of the diff (ie welded etc) unknown. I really don't want to pull her apart if someone has experienced similar.
Any thoughts would be welcomed..
Cheers, HarryO
Sandman Offline
#2 Posted : Tuesday, 20 February 2007 6:40:10 AM(UTC)
Sandman
Sounds like the star gears are stuffed. have u been chuckin burnouts, only spinning one wheel??
What noise does it make when u turn right??
HarryO Offline
#3 Posted : Tuesday, 20 February 2007 6:44:31 AM(UTC)
HarryO
Hi. Thanks for the reply. No, since I purchased (only on the road recently, haven't touched the diff), have been driving like Miss Daisy. Turn right and no noise. Hope that helps.
hx-sandman Offline
#4 Posted : Friday, 23 February 2007 3:53:41 AM(UTC)
hx-sandman
I had the same problem with a WB ute - turned out some of the gears in the diff were cactus and needed replacing.
HarryO Offline
#5 Posted : Friday, 23 February 2007 7:23:21 AM(UTC)
HarryO
Thanks Nick. Looks like Saturday morning is diff removal day. Thanks heaps for the reply mate. Cheers!!
jabba Offline
#6 Posted : Friday, 23 February 2007 4:31:37 PM(UTC)
jabba
I had a similar problem I had in a toymotor corrosion. Made clunking noises turning in one direction only, and at low speed. Looking at the rear tyres, the left rear tyres were wearing in a very strange pattern. PAtches of wearing alternating from insi
#7 Posted : Friday, 9 March 2007 10:37:59 PM(UTC)
similar with my vy ss holden put recond one in. now it has slight whine at 80km cruising.a diff specialist reckons that quality off these diffs are 2ed rate. he recoed a mates diff. now his is whineing on backing off. specialist does not want to fix it.st
