danny88 Offline
#1 Posted : Sunday, 2 April 2006 3:39:29 PM(UTC)
danny88
what do i do about this
RussVRute Offline
#2 Posted : Sunday, 2 April 2006 6:03:23 PM(UTC)
RussVRute
G'day Danny,
Could be a stuffed speedo or drive gear, but could also be just a stuffed cable or worn driven gear , the 2 latter ones are easy to fix , could just be a cable lubrication issue or a cable change, or just a change of driven gear, but the spe
Edited by user Sunday, 2 April 2006 6:10:03 PM(UTC)  | Reason: Not specified
#3 Posted : Sunday, 2 April 2006 6:39:04 PM(UTC)
A very common fault with HQ through to HZ speedo's was the seal on the speedo cable driven gear. WHen the seal packs it in, gearbox oil works its way up the cable and into the speedo head, giving the symptoms you describe.
To do a proper fix, remove t
#4 Posted : Monday, 3 April 2006 2:17:58 AM(UTC)
Danny
Check for oil in the speedo head as Dave suggested but if there is none coming up the cable then try lubricating it. I worked for a Holden dealer when the EJ, EH and HD were new and this was a common complaint. All we did was pull out the inner
