#1 Posted : Monday, 10 April 2006 6:41:42 AM(UTC)
hi just a quick question,,,
Does any one know if there is any difference
between the red and orange nedle gauges on
the GTS dash all mine look orange but
my fuel and oil gauge nedle looks red?
could this be a cause of my fuel gauge not
working properly even after getting a new sender unit??
is there any difference?
classic oz wreck Offline
#2 Posted : Monday, 10 April 2006 6:51:31 AM(UTC)
classic oz wreck
the needles were originally all red but sun fade/old age makes them go orange..
www.classicozwreck.com.au
#3 Posted : Monday, 10 April 2006 6:57:15 AM(UTC)
yer i thort so just making sure cause this
fuel gauge is really getting on my nerves now
still wont read properly after i put a new sender
unit in and the old sender made the gauge work
back wards..
#4 Posted : Monday, 10 April 2006 7:51:01 AM(UTC)
Actually the red needles are for the early model the orange are for the later. The senders won't work unless they match the gauge. Bit confused you said you put in a new sender and the old sender made the gauge work backwards. What does the new sender do?
#5 Posted : Tuesday, 11 April 2006 5:53:35 AM(UTC)
yer old sender read backwards and once i changed
senders and put the new one in it worked fine
but would not read full.
at a full tank guage read 3/4
and worked to 1/2
once i am at half tank of fuel my gauge will just go to empty.
its pritty $#*#@ u
#6 Posted : Tuesday, 11 April 2006 8:43:21 AM(UTC)
Were these new senders actually new or second-hand? Brand new ones aren't expensive and are available...
Cheers...Dave
#7 Posted : Tuesday, 11 April 2006 9:24:55 AM(UTC)
Sounds like the gauge needs repair. doesn't cost that much
Guest (5)
