RJR Offline
#1 Posted : Tuesday, 11 April 2006 2:52:46 AM(UTC)
RJR
Hi guys,
Would like to know if the 202 (3.3) fits into the FJ with no problems and room for the radiator.
Thanks.
#2 Posted : Tuesday, 11 April 2006 5:27:12 AM(UTC)
Piece of cake 130 to 202 red motors are all identical dimensionally. You just need a modified crossmember to take the side mounts plus a bit of other stuff, depending upon what is there now eg 12V electrics, gearbox mounts plus whatever other stuff is req
#3 Posted : Tuesday, 11 April 2006 6:58:53 AM(UTC)
early red motor is the shot as the grey gear box will bolt straight up , 202 will fitbut may have a bit to much grunt,138 or 149 would be ideal.you will need to weld red engine mount brackets cut off an early front end ,eg hr ,hd , eh etc onto the fjs fro
RJR Offline
#4 Posted : Wednesday, 12 April 2006 2:31:45 AM(UTC)
RJR
thanks for the info guys,
