Hi guys, Would like to know if the 202 (3.3) fits into the FJ with no problems and room for the radiator. Thanks.
Piece of cake 130 to 202 red motors are all identical dimensionally. You just need a modified crossmember to take the side mounts plus a bit of other stuff, depending upon what is there now eg 12V electrics, gearbox mounts plus whatever other stuff is req |
early red motor is the shot as the grey gear box will bolt straight up , 202 will fitbut may have a bit to much grunt,138 or 149 would be ideal.you will need to weld red engine mount brackets cut off an early front end ,eg hr ,hd , eh etc onto the fjs fro
thanks for the info guys,
