#1 Posted : Saturday, 24 February 2007 3:46:41 AM(UTC)
G'day fellas, my HZ has a mountain of rust under the windscreen (scuttle panel?) and i don't want to know what's under that, but first things first. How much work is involved in replacing it? Is cutting and welding required? If it's not possible with the limited tools in my backyard, what sort of price am I looking at to have it done by a professional? Cheers for the input
Duzty Offline
#2 Posted : Saturday, 24 February 2007 6:18:53 AM(UTC)
Duzty
for a start, Rare Spares makes those panels, which makes things a little easier for you.
click on the link under my post for the website, and the part numbers are:
(shortys)
rp127
rp128
(extended)
rp127L
rp128L
(complete)
rp2039 - hj-hz
Munromad2004 Offline
#3 Posted : Saturday, 24 February 2007 6:39:37 AM(UTC)
Munromad2004
This area is a common rust spot on these old Holdens.
You are right when you say you don't want to know what is under that.
Generally what's on the surface is only the start.
Unless you have a well equipped workshop with cutting and welding tools i
#4 Posted : Monday, 26 February 2007 12:38:29 AM(UTC)
Thanks for that fellas. I suppose I might just have to hide and cover it up as best I can then drive it until it dies. Thing is the rest of the body is pretty good, but this looks really bad. The further I dig the worse it gets.
