stumpy Offline
#1 Posted : Tuesday, 11 April 2006 8:04:10 AM(UTC)
stumpy
Can anyone help with advice on front brakes for my project hk ute. It currently has drums with no booster. Some say hq will fit some say hj and hz? I am confused. Will be powered by a SBC or 308 @ approx 400hp.
#2 Posted : Tuesday, 11 April 2006 8:31:01 AM(UTC)
Go to Hopper's Stopper Website. There is a page on there with LOTS of information on upgrading early Holden's brakes.
Cheers...Dave
#3 Posted : Tuesday, 11 April 2006 9:38:28 AM(UTC)
The HQ ones will fit but you need to change the stub axles and the wheel nuts pattern will be different.
HK/T/G disks will bolt straight on but you again have to change the stub axles but at least the bolt pattern is the same. In both cases you will need
stumpy Offline
#4 Posted : Tuesday, 11 April 2006 7:51:56 PM(UTC)
stumpy
Thanks guys, will see how i go
#5 Posted : Tuesday, 11 April 2006 10:12:31 PM(UTC)
Stunpy, HQ, HJ, HX, HZ and WB are all the same basic stubs and discs. The calipers change style and manufacturer along the way.
Simply buy some disc brake stubs with discs and calipers off one of those models and put them on the HK but you will need to s
edelbrock1 Offline
#6 Posted : Wednesday, 12 April 2006 7:43:16 AM(UTC)
edelbrock1
I got some HQ rotors with HK stud pattern from Hoppers Stoppers. These guys were great, got me everything I needed and knew their stuff.
Only thing they didnt tell me, was that you cant use the original HK wheels (14 inch) as they foul on the caliper.
#7 Posted : Wednesday, 12 April 2006 10:38:52 AM(UTC)
Pretty sure you can use HT/HG wheels though
#8 Posted : Wednesday, 12 April 2006 6:29:46 PM(UTC)
You have to be able to use 14" wheels as this is what is STD on HQ. Just not HK offset that's all.
#9 Posted : Thursday, 13 April 2006 6:39:03 AM(UTC)
FYI, when i renewed the rear brake cylinders in my HT ute (boosted disk front) they were a different part number to passenger vehicles items...
