Handgunner Offline
#1 Posted : Friday, 14 April 2006 12:09:33 AM(UTC)
Handgunner
Hi there, just need some advice on which pulleys to run in my HG panno.....its a 307 , which Waterpump /Pulleys should i use - short or long - for A: A thermo fan only setup...or B: an original fan setup...i own a short water pump at the moment but no pulleys yet...any opinions on which one would be better ?..i have no power steering either..so a single belt will suffice. I have no radiator yet either, so will i need to consider the type i get...as to which set up will suit the best?
I am also after stock pulleys to suit if u have them..
Thank you all very much :)
Bang Bang
Bang Bang
#2 Posted : Friday, 14 April 2006 2:10:54 AM(UTC)
The HK and HT 307 used the short water pump, 4 blade fan and a shroud. You can use either water pump setup though. 307's don't get really hot, unless of course they are bored to 327 or bored and stroked to 350 or 377.
#3 Posted : Friday, 14 April 2006 2:36:58 AM(UTC)
Hi Guys.
You beat me to it Byron. But didn't the long water pump only fit 'bolt-hole' type heads, because the long alternator bolt screws into the RH head.
So yes, either will work, but you need 'bolt-hole' heads for the long water pump setup.
D
#4 Posted : Friday, 14 April 2006 5:39:21 AM(UTC)
Terry you are correct, but it's not hard to fabricate up an alternator mount.
#5 Posted : Friday, 14 April 2006 8:09:27 AM(UTC)
Thanks , guys, i will just use my short waterpump then....and try and find some pulleys to suit this, oh yeah , if i go the shroud and fan option will the fan be close enough to the standard type chev / holden v8 radiator? Do i really need thermos, cons
