stu Offline
#1 Posted : Monday, 17 April 2006 10:28:06 AM(UTC)
stu
I HAVE A XC V8 MATCHING NUMBER 4 DOOR SEDAN WITH A GS DASH,GS FUEL CAP EXTRA LEAF SPRINGS WITH A PLATE ON THE RADIATOR SUPPORT PANEL SAYING RALLY PACK.I CHECKED THE ENGINE CODE IT'S ONLY A 302.IT IS THE SQUARE HEADLIGHT MODEL.IT'S PRETTY BEAT UP.IT DOES HAVE WHEEL ARCH TRIMS ON SOME OF IT.I WAS WANDERING HOW YOU CAN VERIFY IF IT IS A GS OR NOT?.THE PREVIOUS OWNERS SAY IT IS.BUT I WOULD NOT SPEND A DOLLAR ON IT IF IT'S NOT AS IT NEEDS SERIOUS WORK.
ANY HELP WOLD BE GREATLY APPRECIATED.
stu
stu
Paul351xb Offline
#2 Posted : Monday, 17 April 2006 5:38:36 PM(UTC)
Paul351xb
GS was available across the range and many were 302s. The rally pack plate means it is a GS. If it has square headlights then it would be a Fairmont. So virtually a GXL without the badges.
stu Offline
#3 Posted : Monday, 17 April 2006 7:23:19 PM(UTC)
stu
thanks
so if i got this car back to decent condition.
new paint,good interior good engine
what sought of $$ value.
any is there anything else to make sure it's a gs as the id plate on the support panel is only flimsy thing with one screw holding it
stu
Paul351xb Offline
#4 Posted : Monday, 17 April 2006 11:02:39 PM(UTC)
Paul351xb
It's hard to say if it's a factory GS. The fact that your car still has a plate saying rally pak is a surprise in itself. If you want to know what the car is worth check out trading post and see what they are selling for there. XAs and XBs are comandin
#5 Posted : Tuesday, 18 April 2006 6:13:28 AM(UTC)
thanks paul i also have an xb with log books and only 90,000 gen klms
pity it's a six pak but in pretty good nick i luv the old girl.
my au111 black xr8 keeps the adrenalin going until i fix this xc,i was considering a rebody on the xc(mine's a bit of
#6 Posted : Tuesday, 18 April 2006 9:00:07 AM(UTC)
G'day Stu
you didn't say what colour,trans type or what the body prefix is ie JG23,JG32,JG34.
most rally packs would have twin headlight grill!
I also belive that factory rally packs have the small i.d tag on the front crossmember below the rad suppor
#7 Posted : Tuesday, 25 April 2006 10:22:32 PM(UTC)
the wiring on a standard xc dash is the same as a gs.the cluster plugs in to a multi-pinned socket. i fitted 1 to my standard xc & all i had to do to get it to work was connect the pink wire to the coil (it was next to the coil taped to the loom)& change
stu Offline
#8 Posted : Saturday, 6 May 2006 6:43:42 AM(UTC)
stu
SEATS
XC FAL SED A 5 4- 77
JG23TP9495 K
ENGINE P TRANS B
TRIM U PAINT W
HAS A MATCHING NO V8 T BAR AUTO FITTED.
HAS A RALLY PACK BADGE FITTED TO RADIATOR SUPPORT ON LEFT FRONT.
HELP ME VERIFY IF THIS IS A GS OR A RALLY PACK OR FAIRMONT OR NE
stu
Paul351xb Offline
#9 Posted : Saturday, 6 May 2006 8:50:08 PM(UTC)
Paul351xb
There was also the "country pack" Rally pack had slightly bigger sway bar and more harder suspension from memory. Country pack had slightly raised suspension as well as a sump protector. GS is another option again but was usually included with the othe
stu Offline
#10 Posted : Tuesday, 9 May 2006 5:43:48 AM(UTC)
stu
thanks paul
the 6 cylinder xc i just bought has the sump protector,sports dash,soft wheel,fluted bonnet but it did not have a flip cap.i am going to drop the v8 out of the other xc in this one as this car is pretty tidy.i am probably ruining it but it m
stu
Paul351xb Offline
#11 Posted : Tuesday, 9 May 2006 9:39:23 AM(UTC)
Paul351xb
Stu,
I'd whack an 8 in myself. If you're going to have "show" might as well have a bit of "go". You can always keep 6 and it's bits in a corner of the shed should you want to return it to original one day.
You might have to change the tacho in t
stu Offline
#12 Posted : Wednesday, 17 May 2006 6:02:56 AM(UTC)
stu
yeh same holes as the 8 cylinder i have fitted the gs cap although i found rust when i removed the spill cover.do you know much about the wiring as the harness can be unplugged in several places.just behind the firewall there is plugs do you think i can u
stu
Paul351xb Offline
#13 Posted : Wednesday, 17 May 2006 9:03:38 AM(UTC)
Paul351xb
Stu,
you may be able to use the 6cyl loom. Just compare it to the V8 one. Usually it just means adding a few extra lengths of wire here in there in the bay to make them reach.
Tacho wire for example.
All the wiring under the dash should be fine, just
#14 Posted : Thursday, 18 May 2006 12:27:29 AM(UTC)
G'day I have the same question as Stu how can I tell If my xc ute is a GS here are some no's XC FAL UTE M 3 11 / 77 JG40TD ENG E TRANS N TRIM Z PAINT 5(i think) SERIAL NO 70006 any help would be greatly appreciated.
Matty
ford built
stu Offline
#15 Posted : Thursday, 18 May 2006 1:43:55 AM(UTC)
stu
yeh i have the surround.i might not cut the support panel after all.
paul matty needs you duty calls.
stu
stu
Paul351xb Offline
#16 Posted : Thursday, 18 May 2006 9:51:12 AM(UTC)
Paul351xb
Stu, almost forgot. JG34 is Fairmont sedan.
Matty, JG40 is Falcon ute. 250 motor with a 3 on the tree. I'd be surprised if it was a GS. If however it is a GS from the factory it would have GS dash, bonnet, factory spotlights, flip cap and as Tony s
#17 Posted : Thursday, 18 May 2006 7:48:32 PM(UTC)
Thanks, is that what the tags mean ? because its a tbar auto 351 I am going to sell it I was just wondering what price I should sell it for or just wreck for parts it has gs dash and grill thats why I thought it might be a GS. Thanks again for your help.
#18 Posted : Thursday, 18 May 2006 7:49:45 PM(UTC)
It does have the GS bonnet too
ford built for enjoyment
Paul351xb Offline
#19 Posted : Thursday, 18 May 2006 8:34:42 PM(UTC)
Paul351xb
Sounds like a nice car anyway. JG40 is falcon ute. E is 250 high compression motor. N is three on the tree. Was the car registered as a V8 when you got it? Is there much wrong with it? The XC utes look excellent done up. Used to be a gun metal gre
xcrpakute Offline
#20 Posted: : Friday, 19 May 2006 4:26:11 AM(UTC)
xcrpakute
G'day paul
Well I'm confused. My ute has JG41 and I thought all utes are JG40,
only had the ute 2 years just noticed that.
Tell me more about the country ralley pack utes
Cheers. Tony
Guest (10)
This page was generated in 0.092 seconds.
