#1 Posted : Wednesday, 28 February 2007 6:09:48 PM(UTC)
ARE FLEXPLATES AND FLYWHEELS THE SAME THING ?????????????
#2 Posted : Wednesday, 28 February 2007 9:35:57 PM(UTC)
Sort of, but not really.
A flywheel is used with a manual transmission. It has the ring gear (for the starter to engage) around the outside as well as mountings for the Pressure Plate. They are reasonably thick.
A flexplate also has the ring gear at
#3 Posted : Thursday, 1 March 2007 12:12:12 AM(UTC)
Thanks DAVE,
So if i am going to fit an auto box, i use a flexplate ?
#4 Posted : Thursday, 1 March 2007 2:56:18 AM(UTC)
Yep...
If you get the chance to see the 2 side by side, the difference is obvious.
Cheers...Dave
#5 Posted : Thursday, 1 March 2007 10:59:53 AM(UTC)
Flywheel weighs about 10kg, flexplate (or torque plate) weighs about 1.
They are interchangeable but you would only interchange if you are going manual to auto or auto to manual.
This page was generated in 0.080 seconds.
