#1 Posted : Wednesday, 28 February 2007 6:09:48 PM(UTC)
You are a member of these groups:: Guests
ARE FLEXPLATES AND FLYWHEELS THE SAME THING ?????????????
#2 Posted : Wednesday, 28 February 2007 9:35:57 PM(UTC)
Sort of, but not really.
A flywheel is used with a manual transmission. It has the ring gear (for the starter to engage) around the outside as well as mountings for the Pressure Plate. They are reasonably thick.
A flexplate also has the ring gear at
#3 Posted : Thursday, 1 March 2007 12:12:12 AM(UTC)
Thanks DAVE,
So if i am going to fit an auto box, i use a flexplate ?
#4 Posted : Thursday, 1 March 2007 2:56:18 AM(UTC)
Yep...
If you get the chance to see the 2 side by side, the difference is obvious.
Cheers...Dave
#5 Posted : Thursday, 1 March 2007 10:59:53 AM(UTC)
Flywheel weighs about 10kg, flexplate (or torque plate) weighs about 1.
They are interchangeable but you would only interchange if you are going manual to auto or auto to manual.
