Handgunner Offline
#1 Posted : Thursday, 27 April 2006 8:16:18 PM(UTC)
Handgunner
Hi Kids,
My question is.....Can i run a B & M shifter in my Hg Panelvan fitted with an factory auto console?
I am considering a Mega or Quicksilver shifter and as these are cable operated i guess i can position them most anywhere, but was wondering about the shifters bulkiness fitting under this console....
And also , if it fits under, will the shifters forward / backward operation actually fit in the consoles original shifter slot?
The console is not in the car and i have not purchased a shifter just yet, so any other ideas would be very helpfull.
Gonna run a TH350 or a 400 or a glide...and dont like my chances of finding a stock shifter to use.....also the car is not an original resto , so i just want a shifter that i can rely on / easy to use :)
Thank you in advance.......
Bang Bang
Bang Bang
Simmo Offline
#2 Posted : Friday, 5 May 2006 7:23:23 PM(UTC)
Simmo
I'm about to go through this process with a TH400 in a HK. Im using a Hurst Promatic (Same as Quicksilver) as it doesnt have a separate lever for reverse lockout (instead the shift lever rises). I imagine I'll have to cut up the shifter a bit where it mig
Simmo Offline
#3 Posted : Friday, 5 May 2006 7:23:23 PM(UTC)
Simmo
Im about to go through this process with a TH400 in a HK. Im using a Hurst Promatic (Same as Quicksilver) as it doesnt have a separate lever for reverse lockout (instead the shift lever rises). I imagine Ill have to cut up the shifter a bit where it might
#4 Posted : Thursday, 22 June 2006 3:19:32 AM(UTC)
Finally got this operational. A bit of mucking around but have ended up with stock looks but ratchet shifter. Used the Hurst shifter Promatic (Cheaper and just as good or better than B&M). Had to mount console about an inch back from original so shifter c
#5 Posted : Thursday, 22 June 2006 10:18:07 AM(UTC)
My first car was a HK Monaro. I was only 16 when i bought it( some years ago now).
I mounted the B & M Mega shifter into the console running a turbo 350 in it. Had no ploblems with it and looked fantastic!
ozchevy Offline
#6 Posted : Friday, 23 June 2006 3:37:10 AM(UTC)
ozchevy
I've got a spare second hand shifter from a second generation Camaro sitting here if your interested.
ozchevy Offline
#7 Posted : Friday, 23 June 2006 3:37:10 AM(UTC)
ozchevy
Ive got a spare second hand shifter from a second generation Camaro sitting here if your interested.
#8 Posted : Thursday, 27 March 2008 6:43:07 AM(UTC)
hi. lm after a B&M shifter for my HQ one Tonna. where is the best place to get one.
Cheers Peter.
#9 Posted : Thursday, 27 March 2008 6:43:07 AM(UTC)
hi. l'm after a B&M shifter for my HQ one Tonna. where is the best place to get one.
Cheers Peter.
This page was generated in 0.123 seconds.
