#1 Posted : Sunday, 30 April 2006 11:34:20 AM(UTC)
hi all have been told i need new module can anyboy tell me how to do it
gmholdman Offline
#2 Posted : Sunday, 30 April 2006 8:28:56 PM(UTC)
gmholdman
Hi, if you need one for a VS I have a good one for $90 in Melb.0409 135900 Al.
#3 Posted : Monday, 1 May 2006 6:13:31 AM(UTC)
What type of car is it mate and i will give u all the info u need. Luke
#4 Posted : Tuesday, 2 May 2006 2:30:11 AM(UTC)
wh statesman v6 supercharged.currently disconected and dash shows 3 lights on.
FastEHHolden Offline
#5 Posted : Tuesday, 2 May 2006 3:06:45 AM(UTC)
FastEHHolden
$700 for Holden to do it..and this is one case where they should do it because you have to replace it with the exact same part (I was told there is 5 or 6 different ones)..and the number is on the bottom and you cant see it until you get the part out...co
#6 Posted : Tuesday, 2 May 2006 3:24:51 AM(UTC)
yea i was thinking same thing.I took car last week to gm to put on computer and they came up with abs module and disconected it to see if anything else went wrong for a week before they started pulling car apart. So far only 3 lights on dash any car seems
#7 Posted : Tuesday, 2 May 2006 8:14:38 AM(UTC)
Hi Guys.
If youre in Sydney I supply & fit these for $399.00 with 2 years warranty.
I keep all the various part numbers & have a Tech 2 analyser.
Dr Terry.
#8 Posted : Tuesday, 2 May 2006 8:14:38 AM(UTC)
Hi Guys.
If you're in Sydney I supply & fit these for $399.00 with 2 years warranty.
Dr Terry.
#9 Posted : Wednesday, 3 May 2006 10:06:59 AM(UTC)
ECM Removal and Installation Procedures
The ECM is located on the Hydraulic Modulator in front of the brake master cylinder.
The ECM for ABS and Traction Control is different to the ECM for ABS Only Systems.
The ABS and Traction Control ECM for manual
#10 Posted : Wednesday, 3 May 2006 6:04:03 PM(UTC)
Hi luketroth.
We fit a lot of these units & you are correct about the bad earth connection, Ive seen that re-occur twice.
Weve found this can all be done without diconnecting the brake lines & therefore no need to bleed system, quicker & cleaner.
#11 Posted : Wednesday, 3 May 2006 6:04:03 PM(UTC)
Hi luketroth.
We fit a lot of these units & you are correct about the bad earth connection, I've seen that re-occur twice.
We've found this can all be done without diconnecting the brake lines & therefore no need to bleed system, quicker & cleaner.
#12 Posted : Thursday, 4 May 2006 3:36:22 AM(UTC)
FastEHHolden
You know what I hate?...finding a good deal AFTER you needed it...unfortunately I got it done when my gearbag was getting done and the next time it stuffs up I'm burning the car..so its good to know you do it nice and cheap Dr. Terry...just wish I had bot
#13 Posted : Thursday, 4 May 2006 3:36:22 AM(UTC)
FastEHHolden
You know what I hate?...finding a good deal AFTER you needed it...unfortunately I got it done when my gearbag was getting done and the next time it stuffs up Im burning the car..so its good to know you do it nice and cheap Dr. Terry...just wish I had both
Paul85 Offline
#14 Posted : Monday, 30 June 2008 5:57:36 AM(UTC)
Paul85
luketroyh,,
which loose ground are you refferieng too?? My lights come on intermitently, wanna sus out everything i can before replacing it. I have a 99 VT II V6 S/C.
V6 S/C, 10PSI boost, 1:9 Rockers, Type S CAI, Twin redback catback, Cooler plugs, Top gun Leads.
#15 Posted : Sunday, 16 November 2008 2:28:07 AM(UTC)
can i remove the abs moduile and replace it , but drive the car without it in there,
This page was generated in 0.111 seconds.
