6pak Offline
#1 Posted : Friday, 2 March 2007 8:01:09 AM(UTC)
6pak
Hi folks. I've just picked up a new set of DBA rotors for the ZD along with some new front wheel bearings. The bearing cones are obviously machined to be a snug fit in the hub, what's the best way to install them? Tapping them in with a suitable drift or getting someone with a hydraulic press to press them in? Cheers
#2 Posted : Friday, 2 March 2007 8:15:25 AM(UTC)
Usually, I use a 3 to 5 mm drift/pin punch and GENTLY tap them all round their circumference until they are properly seated in the hub. Make sure your hub is really clean first though.
They should be snug but not too tight. If you allow the cup to twis
Edited by user Friday, 2 March 2007 8:17:11 AM(UTC)  | Reason: Not specified
I_am_josh Offline
#3 Posted : Friday, 2 March 2007 9:10:02 AM(UTC)
I_am_josh
That works alright, but what I do is use the old cones (with new disks i spose you'll have to knock them out of the old hub) to knock them in.
Line up the new cone on the hub (suggest doing the inner/larger bearing first), and sit the old cone, with the
<<<just me>>>
6pak Offline
#4 Posted : Friday, 2 March 2007 9:44:10 AM(UTC)
6pak
Thanks Dave & Josh. Your advice should make this job pretty straight foward! Cheers :)
This page was generated in 0.088 seconds.
