#1 Posted : Saturday, 6 May 2006 4:31:53 AM(UTC)
Hi I am new here and had a question to do with some Torana wheels I got off my uncle.
I got them home and tried to put on the hubcaps but they do not have the lugs on the wheel for cap fitment at all. Nothing?, the wheels i took off have lugs for the caps to hook on to. These wheels have none.
The reason I got them is they look wider than my original LJ wheels.
Can some one tell me what the story with these wheels is?
#2 Posted : Saturday, 6 May 2006 4:58:32 AM(UTC)
might be GTR rims which had a small centre cap held on by the wheel nuts.
#3 Posted : Saturday, 6 May 2006 5:55:45 PM(UTC)
Hi Guys.
'Nibless' type XU-1 rims.
Dr Terry.
#4 Posted : Saturday, 6 May 2006 7:11:06 PM(UTC)
they are worth $$$ to an xu1 owner
classic oz wreck Offline
#5 Posted : Monday, 8 May 2006 5:39:40 AM(UTC)
classic oz wreck
if you have a set of 4 remove the tyres to identify the date codes...last set i put on ebay made just under $1000 ....they would have made more if they had an early date code but the set i had were a last run in 76...
www.classicozwreck.com.au
Dylan Offline
#6 Posted : Monday, 8 May 2006 7:37:45 AM(UTC)
Dylan
if you can get that sort of money for them, sell them and spend the money on widening the stockies, cant remember exactly what it costs, but i think i was quoted less than $150 per wheel to fit 15x8 rims to my GTS wheels.
David Offline
#7 Posted : Monday, 8 May 2006 8:42:42 AM(UTC)
David
Are the LC GTR steel rims the same as the XU1 steel rims? I have a set of LC GTR 6 inch steel rims. They're not for sale, but I was just wondering whether they were worth good cash. The other thing is that once I pull the Torana out of storage, I'll make
#8 Posted : Monday, 8 May 2006 10:08:22 AM(UTC)
LC GTR's ran 5½" wide rims (which will measure 6½" from outside to outside) whereas the XU-1's ran 6" wide rims (which will measure 7" from outside to outside).
If you have 6" LC/LJ rims, they are XU-1 wheels AFAIK.
Cheers...Dave
#9 Posted : Monday, 8 May 2006 6:49:52 PM(UTC)
Hi Guys.
AFAIK all LC/LJ GTR & XU-1 steel wheels are 5.5", only the Sprintmaster alloys were 6".
When XU-1s were 1st released in 1970 they just used the GTR rims. Around the 1971 Bathurst CK release they introduced the stronger 'nibless' rims & thes
#10 Posted : Monday, 8 May 2006 7:59:28 PM(UTC)
classic oz wreck
terry is correct,5.50jj is the xu1 rim...sprintmasters were 6 inch and the only wheel in that width for torana...search on ebay..item number 4624789655..its an auction that has ended but still comes up and shows the date coding...
Edited by user Monday, 8 May 2006 8:53:25 PM(UTC)  | Reason: Not specified
#11 Posted : Monday, 8 May 2006 10:27:39 PM(UTC)
4 cyl Commodores had the wheels that you describe. Torana wheels with no lugs for the hub caps.
JBM Offline
#12 Posted : Monday, 8 May 2006 10:57:23 PM(UTC)
JBM
#13 Posted : Tuesday, 9 May 2006 12:07:15 AM(UTC)
Hi JBM.
I assume we're talking about 13" Torana style rims.
The L34 & A9X are a spoke style rim & are 14"
Jim's point about the Commodore 4 rims is a good one, I wonder how much different the offset is.
Dr Terry.
#14 Posted : Tuesday, 9 May 2006 12:20:40 AM(UTC)
Edited by user Tuesday, 9 May 2006 12:32:33 AM(UTC)  | Reason: Not specified
#15 Posted : Tuesday, 9 May 2006 3:32:09 AM(UTC)
Hi JBM.
Edited by user Tuesday, 9 May 2006 3:42:34 AM(UTC)  | Reason: Not specified
#16 Posted : Tuesday, 9 May 2006 4:35:13 AM(UTC)
Strooth.
I had no idea these wheels could be worth something.
Had another chat to my uncle.
He told me he got the rims off a mate many years ago with the intention of putting them on a trailer.
The car was a hot Torana but he knows less about cars t
David Offline
#17 Posted : Tuesday, 9 May 2006 8:33:52 AM(UTC)
David
Bright pink sounds like an early Torana. They had some amazing colours.
I've now worked out I have a set of 5.50JJ rims. That means I'm rich!!!
Only joking!
#18 Posted : Tuesday, 9 May 2006 9:23:59 AM(UTC)
Bugger, I was thinking of the SLR5000 rims when I mentioned the 6" version...I had a set on an LJ which is what confused me. Well, that's my excuse anyway :-)
Thanks for the correction Dr Terry.
Cheers...Dave
Guest (17)
This page was generated in 0.080 seconds.
