Fastlane
Holden Forums
Holden General Discussion
K/G Floor shifters - which one to keep
I have a powerglide and a trimatic floorshifter for HK and HG. I need to sell one to recoup some costs. The HK will initially have a powerglide installed but will probably upgrade to T350 some time later. Should I sell the Glide shifter and will the 3spd one adapt easily enough to the 2 speed or should I keep the powerglide shifter and sell the tri? What would you do? They are both in good condition
Confused and Undecided Bill
You really need the powerglide one for the powerglide and the trimatic one for the TH350. The trimatic one should operate the powerglide though.
_______________________________________________________ If we all had the same (good) taste, who would buy |
Watching the prices on ebay, the trimatic shifter should sell for more than the powerglide as I believe they are rarer, however this will see you in strife when you want to go to a 3 speed transmission later on.
I would personally hold off and save a f
The powerglide shift pushes forward when you push the lever forward and trimatic pushes rearward when you push forward, therefore you cannot adapt the powerglide to trimatic.
Not sure about the adapting to turbo 350.
Warren
Thanks very much, that gives me a much better basis on which to make a decision
Bill
i agree with what munromad says. rare parts are easy to sell, not so easy to buy.
--- i'd rather hated for who i am than loved for who i am not.
Fastlane
Holden Forums
