#1 Posted : Tuesday, 23 May 2006 3:32:23 AM(UTC)
Hello i have a genuine 307 4 speed HK monaro. It has the hump in the rear in boot, track rods and has bump in transmission tunel. The car came with a 350 chev and a powerglide. I purchased a saginaw gearbox, shifter and bell housing, originaly from a HT 350 monaro. Can I remove the bracket that holds the shifter to the crossmember and reweld it onto a HK automatic cross member or do i need to find a original HK monaro saginaw cross member.
#2 Posted : Tuesday, 23 May 2006 3:58:14 AM(UTC)
A HK Saginaw crossmember is the same as a Powerglide one. The shifter doesn't mount to the crossmember at all, but to the floor off an angle bracket which bolts to longer seat bolts. The HT shifter is the same, but you need the HK bracket and long bolt th
#3 Posted : Tuesday, 23 May 2006 4:13:39 AM(UTC)
Thanks Byron. Do u know were i could find these parts.
#4 Posted : Tuesday, 23 May 2006 4:26:54 AM(UTC)
Find some and tell me because I have two 4-speed HK's and my mate has two as well and we don't have one shifter bracket between us. I have one bellhousing and it's cracked. Just keep looking. Perry (monaro.com.au) reckons he can make a repro support brack
hainzy Offline
#5 Posted : Wednesday, 24 May 2006 3:43:02 AM(UTC)
hainzy
Bloody hell Byron. The knowledge in that head of yours is incredible. If it wasnt for people like you theyre be a lot more holden fans running around like headless chickens. Craig did well with his blue monaro!
edelbrock1 Offline
#6 Posted : Wednesday, 24 May 2006 4:47:27 AM(UTC)
edelbrock1
I know a guy that owns an original HT 307 4 Speed. You know him too Byron. So there is at least one out there.
74HJLS Offline
#7 Posted : Wednesday, 24 May 2006 7:51:37 AM(UTC)
74HJLS
As far as I know all HK 307s were autos.
Pete.
Pete.
#8 Posted : Wednesday, 24 May 2006 4:34:08 PM(UTC)
The shifter bolts to the crossmember on every HK that I have worked on, the piece you are talking about Byron is just a brace, and is simply a piece of angle with a small bend in the end and a hole for the centre of the shifter.
The crossmemebers are s
#9 Posted : Wednesday, 24 May 2006 7:41:20 PM(UTC)
Warren, you learn something new every day. I've never seen a HK Saginaw crossmember in the flesh then. More searching for stuff my HK then.
On the HT 307 4-speed front, that is where I think the 'no 4-speed 307 HK' myth came from ie all 307 HT's were Pow
#10 Posted : Wednesday, 24 May 2006 8:20:29 PM(UTC)
Byron,
See page 178 of yellow parts book, part 21 is welded to crossmember.
page 214 shows hanbrake, part 6 cannot have hook on end for return spring "12"
If you do not have the yellow book, try Monaro sup workshop manual page 7-12 shows crossmem
#11 Posted : Wednesday, 24 May 2006 10:10:42 PM(UTC)
I know whom you are talking about now. Again, you sometimes learn two or more things a day.... How rare are Saginaw 307 HT's? AFAIK they were not officially available.
#12 Posted : Thursday, 25 May 2006 6:34:52 PM(UTC)
I have pictures of both shifters the HK holden had two shifters the early one had the shifter bolted to the floor. It had trouble jumping out of gear under heavy acceleration. A change was made half way through the model and the shifter was then mounted t
#13 Posted : Thursday, 25 May 2006 10:08:24 PM(UTC)
Just found out that as I thought, the 307 manual HT officially never existed. Just like HQ 350 Premiers (4 made), VK EFI with M20 and other such 'specials'. The 4th Pagewood car is indeed a factory 307 HT 4-speed and may be the only one, but a few other '
#14 Posted : Friday, 26 May 2006 12:23:27 AM(UTC)
My 307 4 speed donor car was made in the 8th month 68 (just after release)and it had the shifter to the cross member, The workshop manual also only shows to the crossmember, so before the workshop manual was made. AFAIK the workshop manual was avaialable
#15 Posted : Monday, 29 May 2006 3:24:28 AM(UTC)
luketroy, don't cut the brace off the ht crossmember, I saw one on E-bay with a shifter for $1800. All hk's with 307-327 4 speed had a unique crossmember with the brace to hold the shifter. hk crossmembers were not adjustable like the others.
#16 Posted : Monday, 26 June 2006 12:35:50 AM(UTC)
I know a guy who purchased a silver mink 307 with saginaw, I can assure you this car is original, and was purchased by the fellow in question, and is still owned to this day. Very nice car. I have also read many times this combo never existed, I can onl
#17 Posted : Monday, 26 June 2006 12:36:48 AM(UTC)
oh, and its a HK.
#18 Posted : Monday, 26 June 2006 6:01:09 AM(UTC)
Saginaw behind a 307 in a HK is common, but officially non-existant in a HT.
#19 Posted : Wednesday, 28 June 2006 7:58:09 AM(UTC)
Ah ok, I didnt know that, I've read in magazines and the like that all 307 munro's supposedly came with auto's, but this is obviously not the case. Cheers.
#20 Posted : Wednesday, 28 June 2006 10:30:43 PM(UTC)
That piece of misinformation has been around for years. I believe it originated from the HT range where it is actually true (bar a handful of specials). Somehow over time or in printing errors HT became HK. When the HT was released if you wanted a V8 auto
