Hi folks
Can someone tell me if the VR transmission can be fitted to a VS 97?
I know one is the ecotec engine and the other is something different but wasn't sure if the boxes were different.
If it is possible to fit a transmission from the VR to the VS are there other things that need to be considered like ECU BCM etc?
Mark H
1st NO but ther is a sticker ontop of the auto it will say sumthing like HDD its a wight sticker up front at top you need an auto with the same NO: on the sticker coz thers likr 3 diff autos for vs.
the VR and VS are worlds apart. The VS introduced the ecotec motor (145kW) while the VR ran the original buick V6 (125kW)there are no common parts between the two. the blocks are completely different, as are all the internals and externals; and of course
Hi Guys.
They are not that different. Yes, most engine parts are non-interchangable, but the gearbox bolt pattern is the same. A VR V6 box will bolt into a VS (or later), but it is electrically different and will not shift properly. If you swap the val |
Thanks Dr Terry
That is the information I was after.
I am aware that the engines are toatally different.
The situation I have is my son has a late model VR sedan with good running gear which now has a stuffed body ater some low life T-boned t
